Thread: Cure LED Sidelight Canbus Problems.
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Cure LED Sidelight Canbus Problems.
    #11
    Apr 2010
    Ashford, Middlesex
    They do make a hell of a difference! Do you need to use resitors in line with all of them, or do the LED bulbs have the resistors built in?
    Lang may yer lum reek!
    Current: '09 Audi A4 Avant SE TDI (143)
    Previous: '56 VW Passat 2.0TDI SE - I survived 'BKP' ownership!
  2. Re: Cure LED Sidelight Canbus Problems.
    #12
    Dec 2009
    14 Post(s)
    All the leds in my car have resistors built in. Not sure if the canbus only works on the outside lights. The only failures I have had have been the sidelights.
    I hope if and when these ones rust they will still work as it was the resistor playing up and not the leds. They lasted just over a year so cant be bad really .
    Basically they a small circuit board with resistors soldered to them along with the leds.
  3. Re: Cure LED Sidelight Canbus Problems.
    #13
    Apr 2010
    Ashford, Middlesex
    Where did you get them from Rappy, and are they just plug & play?
  4. Re: Cure LED Sidelight Canbus Problems.
    #14
    Dec 2009
    14 Post(s)
    Quote Originally Posted by fat controller View Post
    I got mine from here
    http://www.bettercarlighting.co.uk/i...ewCat&catId=42
    I would suggest calling and asking for Gil. And yes they are plug and play
    PM me for more info.
    Oct 2010
    Here And There
    Quote Originally Posted by rapport25 View Post
    That link does not work Rapport
    Edit - does now that there is a ? after the php ;-)
    Sent from my iPhone using Tapatalk as I cant be ***** turning on my laptop !
  6. Re: Cure LED Sidelight Canbus Problems.
    #16
    Apr 2010
    Ashford, Middlesex
    Thanks guys
    Link bookmarked, and on the 'to get' list
  1. Alarm LED
    By Blackthorn in forum Golf MK6 - 2009 - 2013
    Last Post: 22-07-2011, 07:58 PM
  2. 1.8T Common Troubleshooting Guide
    By blacksline in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2010, 12:17 AM
  3. LED sidelight upgrade.grrr!
    By interjays in forum Audi A3 - Archive Topics
    Last Post: 19-03-2008, 10:00 PM
  4. Replies: 22
    Last Post: 08-03-2008, 08:16 PM
  5. Replies: 0
    Last Post: 15-12-2007, 04:37 PM
