Thread: luggage compartment warning??
Results 1 to 10 of 10
  1. luggage compartment warning??
    May 2009
    wakefield
    Hello there wonder if someone could help me.
    ive got a mk4 golf 1.9tdi 2002
    when i put ignition on/start vehicle ,luggage compartment open warning light comes on dash even tho closed correctley,also when i lock the car the indicators dont flash,but do upon opening the car.....anyone any ideas....please help,both faults appeared at same time....thanks....martyn.
  2. Re: luggage compartment warning??
    Jan 2009
    towcester northants
    water has got into the boot catch
    probably need new catch and the 3 little wires replacing to the switch
    this is caused by the rear washer hose coming off of the rear wiper motor
  3. Re: luggage compartment warning??
    Dec 2007
    Belfast
    Yep ! Totally agree with the above.
    You have a leak in the rear washer mechanisim.
    Very common fault with the MK4.
    You have been using the rear water jet to clear your rear screen and it has leaked into the sensor in the lock.
    I had exactly the same problem on my car. I guess if you leave it for a couple of days, it will dry out.
    You say that when you lock the car the indicators dont flash which would suggest you have an alarm in the car. The reason this may happen is cause with the boot playing up, you have an incomplete circuit.
    The best way to address this is to take the panel on the inside of the boot lid and check the water pipe is firmly and securly on, Once this has been done, maybe put a cable tie around the join and see how you go. If it dries out over a couple of days and you address the issue of the water pipe, you may not need to replace the lock.
    The above post is based on my own experience with the same problem.
    Good luck.
  4. Re: luggage compartment warning??
    May 2009
    wakefield
    thanks to ya both absolutly spot on,havent used washer for couple of days and the problems cured itself,will look in tailgate at weekend and cure leak.......ive another slight prob if anyone can help.......interior light on drivers door only works when it wants to(MOST OF TIME WONT WORK) also kurbside light.....im thinking curtusy light switch on door which is pressed/released when door open/closed only i cant find one...anyone help on this? thanks mart
  5. Re: luggage compartment warning??
    Jan 2009
    towcester northants
    door catch!
    the courtesy light switches are in the catches
  6. Re: luggage compartment warning??
    May 2009
    wakefield
    so do i have to replace the catch to solve problem?
  7. Re: luggage compartment warning??
    Dec 2007
    Belfast
    From what you say in your post, it sounds like you have a problem with your door lock mechanisim. I, very recently had a similar problem were my kerb light was on all the time and the same with my courtesy light, even when the door was closed, though I also had a central locking issue aswell.
    I would suggest that you get a fault code read done first to see if there are any other problems with the door.
    The door locks are about £117, and for someone who knows what they are doing, very easy to fit, about an hour.
    Personally, it may be the start of further problems to come.
    This post is based on my own experience.
    Good luck/
  8. Re: luggage compartment warning??
    May 2009
    wakefield
    looked at the pipe leading to motor and indeed it was split,simply replaced using aquarium airpipe ,good as new now and electrics fine.
    many thanks......just gotta look at that drivers door catch/switch now.
  9. Re: luggage compartment warning??
    paddycars Guest
    Hope you dont mind a newbie replying but I have the same problem with the luggage compartment warning showing, as with everybody else my problem started with a leaking wiper and now the dash is showing the tailgate isnt shut and as a result when the alarm is activated the lights dont flash as the brain thinks the tailgate is open. My problem is that the leak has been cured for about 4 weeks and the problem still exists, anyone got any ideas? Cheers
    Dave
  10. Re: luggage compartment warning??
    Southampton, UK.
    If you're sure there is no moisture in the door lock mechanism, then it could be the micro switch within the mechanism that is faulty. Possibly a failed soldered joint, which is known to happen on front DLM's. See here.
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 379,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
    2015 Audi A6 Avant 2.0 TDI ultra 190
  1. Help needed with golf mk4 luggage warning
    By gbeagan in forum Golf MK4 - 1999 - 2004
    Last Post: 16-01-2010, 05:31 PM
  2. Luggage Compartment Open
    By skoda86 in forum Octavia
    Last Post: 26-03-2008, 05:54 PM
  3. World Debut For The All New Audi A3 Cabriolet
  4. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
