Thread: A4 leak into footwell!
Results 1 to 10 of 13
  1. A4 leak into footwell!
    Jan 2010
    addlestone UK
    Hi
    Used my A4 estate today first time for about a week and found passenger footwell and rear swimming in water!
    I can see it running down the carpet from under the dash
    any idea before I start taking things to bits?
  2. Re: A4 leak into footwell!
    Jul 2008
    stoke on trent
    check plenum chamber (where battery is) see if its full of water, if so unblock drains plenty of info on this problem if you search forum
    99 a4 b5 1.8tqs saloon
    99 a4 b5 2.5tdi avant
    90 eunos roadster
  3. Re: A4 leak into footwell!
    Oct 2009
    buckingham, buckinghamshire
    as above, but also check the gromit where the bonnet release cable goes through too.
    also something else to check is that little plastic cover over your pollen filter.
    Audi A6 2.8 quattro avant.... as dead as a dead thing now
    now messing about in a mk4 2.0 golf gti..
    thats gone...now into an 03 passat 2.0 sport
  4. Re: A4 leak into footwell!
    Jan 2010
    addlestone UK
    great thanks guys will check tomorrow
  5. Re: A4 leak into footwell!
    Jan 2010
    Cape Town, South Africa
    What about the A/C condensate water outlet? Maybe blocked?
  6. Re: A4 leak into footwell!
    Jan 2010
    addlestone UK
    it was the two drain holes under the battery
    the battery tray is almost rusted away!
    unbelievable amout of water came out
    thanks again
  7. Cheap water leak detector.
    Mar 2007
    Have just cleared drain hole (again) under battery after water ingress. This seems to happen every couple of years and following heavy rain. I removed about a gallon of water using my Pela extractor. Looking around Poundland the other day, I came across a "Water Leak Alarm" which looked as if it might be useful for alerting me to a potential flooding situation. The device comes in a small round plastic box and is powered by a 9V PP3 battery. It fits neatly just in front of the brake servo. I did some checks first for battery current and did not see any movement of the pointer on the 1 ma scale. When I bridged the sensor pins with two wet fingers, about 50 ma was drawn from the PP3 and the device emitted a loud screeching sound. So it looks as if this device, if fitted with an alkaline battery, should be OK for a couple of years. I should add that I do regular visual checks for flooding, but obviously not often enough!
    1997 Audi A4 1.9TDI (110, AFN) Auto saloon in Ming blue. Now sold.
  8. Re: Cheap water leak detector.
    Oct 2005
    Poke the drain hole bungs out completely to stop the blocking in the future.
  9. Re: Cheap water leak detector.
    Mar 2007
    Thanks for the tip. I did consider this, but as the blockage is usually caused by a leaf spread across the opening I'm not sure how this would help. What it really needs is a drain hole of about 2" diameter and/or a more effective leaf trap below the windscreen. The vulnerable area seems to be near the passenger door. Unfortunately I live in a heavily wooded area and my roof gutters (house) are another problem.
  10. Re: Cheap water leak detector.
    Jul 2008
    stoke on trent
    you could try and get a scuttle cover as fitted to facelift models
    it stops all but the smallest leaves getting through and fits all earlier models
    90 eunos roadster
  1. Ultra-economical audi a4 tdi gets the ‘e’ treatment
    Last Post: 11-07-2009, 08:11 PM
  2. major water leak problem A4 Drivers side rear footwell soaking wet
    By steve888 in forum Audi A4 - Archive Topics
    Last Post: 17-01-2008, 10:27 AM
  3. Latest Audi A4 Specification Now Sounds Even Better
    Last Post: 06-07-2006, 09:25 PM
  4. Fuel Leak 2002 A4 Avant
    By AWC10 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-03-2006, 08:21 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
