Thread: VW Touran Clutch problem.......
  1. VW Touran Clutch problem.......
    taunton
    Hi, looking for a bit of help. I lost pressure on my clutch pedal before christmas, I have since changed both the Master and Slave cylinders but still have very little pressure (not enough to operate the clutch) even after bleeding etc. Just wondered if anyone had any ideas as to what it could be before I start stripping it down.
    It is a 2004 VW Touran 1.9tdi
  2. Re: VW Touran Clutch problem.......
    May 2010
    Devon England
    hi mate iirc the slave cylinder is inside the box? there must still be air in it or drawing in air at some point in the system, i take it you have had someone pump the clutch pedal till there is no air coming thro? it may pay to use a pressure bleeder on the system mate
  3. Re: VW Touran Clutch problem.......
    taunton
    Hi, thanks for the reply. I have bled the system over and over again, I have checked for leaks etc but still no joy. The slave is ontop of the box. I am thinking that it might be either pressure plate or bearing but obviously want to try absolutely everything first before taking the box off. I have seen a pressure bleeder from Halfords for £20 does anyone if they they are any good?
  4. Re: VW Touran Clutch problem.......
    Jan 2017
    hailsham
    You have to bleed the clutches on tourans with a pressure bleeder. They get a air lock in the master cylinder. I have just finished putting a new clutch in mine today same problem. Pressure bleed it and it was fine.
  1. Steering Lock See Workshop and dealer problem
    By UkMark in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-02-2020, 08:30 PM
  2. VW Golf MK5 idle problem
    By MK5 - Golf in forum Golf MK5 - 2004 - 2009
    Last Post: 23-06-2010, 01:04 AM
  3. Please Help VW Newbie With GT TDI 140 Engine Problem!
    By TonyDB in forum Golf MK5 - 2004 - 2009
    Last Post: 06-06-2010, 09:47 PM
  4. Clutch slave problem?
    By kerrymarkp in forum 80 - 90
    Last Post: 30-05-2007, 01:22 PM
  5. Mk3 Golf Clutch Problem
    By MarkMk3 in forum Golf MK3 - 1993 - 1999
    Last Post: 25-03-2006, 09:46 PM
