Thread: my coupes running badly :(
Results 1 to 10 of 10
  1. my coupes running badly :(
    Jan 2011
    Kilmarnock, Scotland
    recently bought an L reg 2.0 16v coupe.
    been loving it so far but now having a wee issue with it tho.
    was out in it last night and all was going great untill i needed soem fuel.
    went to the shell, and stuck a ten spot of vpower in it, just to see me thru the rest of then night, didn't even get a mile up the road and it cut out on me, no power at all , but stamp the foot to the floor and it will eventually start revving, and away you can go.
    nursed it down to the shed and had a poke about, and noticed a couple of bits n peices, but nothing drastic, most notably that no3 spark plug was VERY sooted up.
    left it at the shed and borrowed another car to finish my deliveries.
    went to it this morning, and it fired first turn of the key, and ran and drove perfect, so took a drive to the garage to get fags, got to the garage fine, no issues, left it running, came back out and it was still idling perfect, then as soon as i went to pull away, bang away it went again, axact same thing, cutting out, idling badly, stamp the foot down and it revs up and you can go.
    gave it a good going over, cleaned all the spark plugs, checked for electrical connectors, vacuum hoses, blah blah usual suspects, and all checks out ok.
    sooooo, the conclusion i can draw ATM is that it must be bad fuel, or doesn't like vpower, either way tomorrow i'll get a new set of sparkers, since the ones in it are indeed well past it, a new fuel filter and drain the tank, flush the lines and ply it with new fuel and see how i go from there.
  2. Re: my coupes running badly :(
    Apr 2009
    I know this doesnt really help but it doesnt sound fuel related to me: I had an 2 litre 8v Audi 80 ('93 plate) which had exactly the same symptoms. It only did it 4 or 5 times over 6 months, it would let me travel 3 miles (almost exactly, it always did it in the same village!) then lose all power. It would idle alright then after 20 or so seconds it would give you power back when you revved hard.
    This is the only trend I saw, I wondered if it was something to do with temperature but never actually found anything wrong with it.
    Sorry I cant actually help you! Good luck
  3. Re: my coupes running badly :(
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    I think your last paragraph is the way to go. Can you get it scanned for faults before you open the wallet too wide?
  4. Re: my coupes running badly :(
    Gwent
    Quote Originally Posted by benjwom View Post
    There may be something in this, I've seen similar in a 16v passat (same injection system) problem was damaged/shorting lambda sensor wires.
    The lambda sensor is not used by the ECU until the coolant temp reaches approx 80 deg C
    The Lambda sensor operates on a voltage range of approx 0.2-0.8v but the other two wires coming from it are for the heating circuit which is something more than this. A short gives dreadful running with no power, but at wide open throttle, the lambda is ignored and fuelling is provided by tables built into the ECU programming.
    suggest you test the lambda sensor
    http://www.lambdasensor.com/main/mtesting.htm
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  5. Re: my coupes running badly :(
    Jan 2011
    Quote Originally Posted by scotty33 View Post
    that makes a lot of sense, i'll check for shorts when i'm down the shed tonight.
  6. Re: my coupes running badly :(
    Jan 2011
    went down to the shed armed with new fuel filter, new spark plugs and ready to start checking things over and...........
    ......................... i can't find the bloody keys anywhere.
  7. Re: my coupes running badly :(
    Jan 2011
    well, got it all sorted out now, keys were in the middle of my work car park >.<
    and the problem was indeed the fuel, cars running great now
  8. Re: my coupes running badly :(
    Oct 2009
    10 Post(s)
    Thought so ,well done and good luck that she stays good
  9. Re: my coupes running badly :(
    Jan 2011
    Quote Originally Posted by fourringsrus View Post
    well, she didn't
    starter has now packed in
  10. Re: my coupes running badly :(
    Oct 2009
    10 Post(s)
    If it ain't one thing it's another, good luck fella
  1. V6 3lt running badly
    By nmmoor in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-06-2010, 12:02 PM
  2. ABD Golf running badly
    By Trog_nfs in forum Golf MK3 - 1993 - 1999
    Last Post: 29-01-2010, 12:54 PM
  3. Please Help Engine Light, Running Slighty Rough....
    By le19h in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-09-2009, 01:03 PM
  4. Please Help passat running badly
    By dermot1949 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-06-2009, 01:52 PM
  5. Straight Diesel Engine Running Badly
    By mattis- in forum Golf MK3 - 1993 - 1999
    Last Post: 14-03-2008, 03:41 PM
