Thread: 2.0 spark plug change
  1. 2.0 spark plug change
    Sep 2007
    Essex boy in Suffolk
    2.0 AZJ engine in a 2001 Beetle.
    I wanted to change the plugs today, changed 1 and 4 without to much problem but 2 and 3 are below the inlet manifold so you cant really see then, let alone get to them.
    The manifold thats above them splits in the middle so I guess you have to remove one half but which side.
    So can anyone tell me how much I need to remove and if I need any new gaskets, or better still, point me at a how to guide cos I aint found one yet.
    Graham
    Still pretending to know stuff.
    Golf 6 .:R
    Corrado 20vT - BBS RCs, Leather, Bremo's, TFSI and DSG
  2. Re: 2.0 spark plug change
    Jan 2010
    Boston
    Hi I looked everywhere for a guide or some help for doing this. In the end I found somewhere that there were two ways of doing it. 1 was to have an array of bendy tools, the other was to take off the whole manifold. Unfortunately I don't have an array of bendy tools, so I had to opt for the latter. I took photos at most steps and I was going to try to produce a 'how to' guide myself to post. It is a complete **** to get everything off, especially as I had no idea where everything was bolted on, but it surprisingly went back on a lot easier.
    I have a Golf but I should imagine it's the same process.
  3. Re: 2.0 spark plug change
    Apr 2010
    Caracas
    Hello,
    I need help, I have a 2005 VW BORA 2.0L automatic, chassis No. 3VWRV49M85M151949, buy it second hand and currently has 28,000 miles.
    When removing spark plug has observed that the original VW part number 101905609 (NGK BKUR5ETC-10), has 3 electrodes. I am looking online and I see that this is going to spark a lot of VW models. almost all smaller displacement, but not the BORA. However in my car, it's been 2 years that I have, doing excellent. According to the catalog of NGK you should go the NGK BKUR6ET-10 and the mention ETKA (VW 101000033AA) which is equivalent.
    The reason is that changing spark plugs at idle sometimes (1 in 10 times) shakes and I think it's up change.
    I ask:
    A. - What kind of plug do I put? the BKUR5ETC NGK NGK-10 or BKUR6ET-10, knowing that BKUR5ETC-10 works to the hair, but the catalog is indicated for the 2005 2.0L VW BORA.
    2. - If I'm using NGK BKUR5ETC-10 I damaged the engine or any other part of the vehicle? Am I at risk using the NGK BKUR5ETC-10?
    Hello, continuing the previous post change to question 3 for this:
    3. - The spark plug (NGK BKUR5ETC-10) has thermal grade 5 and the other 6, the higher the number is colder,
    Is this difference important? Characteristically and other dimensions are equal.
    regards
    Well gladly stay at your service for any further clarification you may have.
    regards
  4. Re: 2.0 spark plug change
    133 Post(s)
    1987 Post(s)
    This is a Mexican built type 9M Bora 1 for the Venezuelan market and a car we do not see as we had the Jetta 5 instead. Is your engine code BBW, BER, BEV, BFF?
  5. Re: 2.0 spark plug change
    Apr 2010
    Caracas
    Thank you for your answer.
    You are correct. made in Mexico and for Venezuelan market.
    Engine Code is BHP
    Please if you know
    What NGK spark plug model do it need?
    Could be BKUR6ET-10 or BKUR5ETC-10 (actually in use)? or whatever?
    Best Regard.
  6. Re: 2.0 spark plug change
    133 Post(s)
    1987 Post(s)
    Please bump this thread later so I see it at home.
  1. Please Help A3 56, 2.0 TDI 'Glow plug broken' opinions please
    By spanglish9978 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-06-2010, 07:58 PM
  2. Own a 99 bora 2.0 sport? Can you do me a massive favor?!
    By comullan1984 in forum Bora - 1998 - 2005
    Last Post: 17-05-2010, 05:33 PM
  3. How to change Glow Plugs 2.0 TDI Sport BKD
    By jennion in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-08-2009, 02:11 PM
  4. Gearbox oil level
    By mowjoe in forum Golf MK4 - 1999 - 2004
    Last Post: 13-08-2009, 01:11 AM
  5. GOLF GTI MK3 2.0 16V ABF engine change
    By mo_schino24 in forum Golf MK3 - 1993 - 1999
    Last Post: 12-03-2008, 12:04 AM
