Thread: Fuel Pump Problem?
Results 1 to 10 of 12
  1. Fuel Pump Problem?
    Jan 2011
    Chamonix Mont-Blanc
    Firstly, Hi everyone - I'm new here but have been browsing the site for a while now.
    I have an A6 2.8 v6 quattro (2000) which I can no longer get to start. I had it idling a few days ago to warm up (-10 here at the moment!) When I went to drive off, the engine died and I can no longer get it to start.
    When turning the ignition, the engine chugs away and almost starts but doesn't quite fire. With the foot to the floor and turning the ignition for about 30 seconds it briefly started but soon died out again.
    I've had a friend look at it and we could see that the Spark plugs are firing OK, there are no fuses blown and we undid the fuel line and when turning the ignition, no fuel cam through.
    He has suggested a new fuel pump but before buying a new one I just wanted to check if this sounded right or if there were any other things I could do to try and diagnose the problem.
  2. Re: Fuel Pump Problem?
    131 Post(s)
    1976 Post(s)
    It does sound like the fuel pump is not delivering fuel but I would make sure it had power before fitting a new one.
  3. Re: Fuel Pump Problem?
    Jan 2011
    Chamonix Mont-Blanc
    Thanks Crasher. Is there an easy way to do that? Am I right in thinking the fuel pump is under the back seats?
  4. Re: Fuel Pump Problem?
    131 Post(s)
    1976 Post(s)
    It is inside the fuel tank, accessed through a panel under the back seat. The fuel tank MUST be no more than ¼ full when tying to remove the pump.
  5. Re: Fuel Pump Problem?
    Jan 2011
    Chamonix Mont-Blanc
    Thanks again Crasher - I've now got the back seat out and located the fuel pump - is there a way of testing it to see if this is actually the problem before buying a new one?
  6. Re: Fuel Pump Problem?
    131 Post(s)
    1976 Post(s)
    Has it got power when cranking and does it pump fuel if it has?
  7. Re: Fuel Pump Problem?
    PM me your email address or post it up in the thread and I will send you a diagram. Regards Peter
  8. Re: Fuel Pump Problem?
    Jan 2011
    Chamonix Mont-Blanc
    Thanks Peter. My post count is too low to PM you. Please could you send it to (removed my email address)
    Thanks very much.
  9. Re: Fuel Pump Problem?
    Jan 2011
    Chamonix Mont-Blanc
    Thanks for all the help on this - I checked everything and it definitely points to the fuel pump. There is power getting to it but it makes no sound at all.
    Am I able to ask on here a good place to get replacement parts online?
    Thanks again
  10. Re: Fuel Pump Problem?
    131 Post(s)
    1976 Post(s)
    Assuming it is an ALG or AQD engine without an auxiliary heater, I think the part number is 8E0 906 087 and the system says you will need O ring 4B0 201 844 and the note,
    on k-pumps with vertical connections on sealing flange, there may be some instances where 90 degree quick fastener 4B0 201 406 has to be used
    According to my work trade system this fuel pump is available aftermarket from a few different manufacturers.
  1. A4 Fuel Pump
    By jules1970 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-10-2009, 10:41 AM
  2. 1.9 PD TDI Oil Change with Pella
    By Col in forum General
    Last Post: 21-07-2009, 07:56 PM
  3. Fuel Problem on 2000. 115bhp TDi Passat.
    By Hugomont in forum Passat - Archive Topics
    Last Post: 15-04-2007, 09:13 PM
  4. A4 Fuel problem, please any help would be great.
    By markcass in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-02-2007, 06:13 PM
  5. 95 Golf TDI Starting Problem Please Help
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 10:55 AM
