Thread: Handsfree kit mounting
Results 1 to 10 of 13
  1. Handsfree kit mounting
    Dec 2010
    Renfrewshire, Scotland
    My car came with a Parrot kit fitted, the small LCD is behind the indicator stalk which is a bit awkward to use and see when driving.
    The fixing of it is loose and I have some No More Nails strips I'm going to fix it back on with - but also considering relocating it.
    Any thoughts where else it could go?
  2. Re: Handsfree kit mounting
    Dec 2009
    14 Post(s)
    I have been looking at the same kit. The Parrots are excellent . I think I will mount mine above the dial that controls the lights.
    Hth's,
    Rappy.
  3. Re: Handsfree kit mounting
    Dec 2010
    Yeah I had a Parrot CK3100 in my B5.5 and it worked really well... it had some issues with my phone at the time (iPhone 3G) and I eventually removed it. When I noticed the B6 had this one fitted I tried it with my iPhone 4 and it works perfectly.
    Whoever fitted it has done a bit of a poor job, the mic is just resting between the sunvisor and roof lining so when you pull down the sunvisor the mic falls down ... it's not a big problem as I'll fit it at the top of the A pillar but I don't understand why they didn't use the clips that come with it exactly for that purpose!
    The screen fitted behind the indicator is the largest flat/clean area of the dashboard for it I think - they stuck it there with cheap sticky pads and it's coming off so I thought about finding somewhere better - I'll try above the light switch but I think it may be a bit tall to sit in there.
    That said, the kit connects fine with my phone and when a call is made or received the radio pauses the track and displays "Phone" - when I installed it in my B5.5 it didn't do that (Could be down to the radio I guess). If you are considering one I recommend it.
    Chris (A man with 3 points for getting caught on his phone!)
  4. Re: Handsfree kit mounting
    Dec 2009
    14 Post(s)
    I have not measured a kit up for location but that seems to be the best place.
    Or with a bit of work stick it over one the draws above the cd player that was another idea I had and when you want to use the kit press the draw open for ease of use then push it back in when finished.
    Maybe you could try this and let me know . I was considering the draw on the left hand side.
    See what you think?
    Rappy
  5. Re: Handsfree kit mounting
    Dec 2010
    I'll clear the snow off the car this afternoon and have a look at mounting it - I'll take some photos of the unit in different places so you can see what it's like.
    The previous CK3100 kit was a little more shallow - that would have been ideal above the light switch.
    A photo of my CK3100 kit fitted to my Seat Ibiza... It later had flickering issues with the display I think was caused by the wire being pinched as I fed it through the fascia.
    No photos of it on my B5.5 but this is where it was located.
  6. Re: Handsfree kit mounting
    Dec 2009
    14 Post(s)
    Quote Originally Posted by Brydo666 View Post
    Great. That would be very usefull. I can imagine the wires being pinched would cause some problems.
    I was considering drill through the draw and feeding the wire straight down to the radio. Not spent to much time on removing the radio and having a look just yet.
  7. Re: Handsfree kit mounting
    Dec 2010
    Sounds like that could work, not sure how clean the metal trim on the drawer would be to drill through?
    One thing to bear in mind is the control box for the kit - this is where the screen connects to... my previous CK3200 kit was like this (And the 3200 is likely the same).
    Blue control box, about the size of a laptop charger.
    A display screen with roughly 2M cable.
    Mic with roughly 4M cable.
    Wiring harness with ISO leads (X2) .. Power & Audio.
    Basically the mic and screen you mount anywhere and connect to the blue control box wherever it is located, the wiring harness takes its feed from your headunit cables and connects to the control box to supply power to the unit.
    Here are a couple of photos...
    The CK3100 kit I used before.
    The CK3200 kit, it seems the control box is smaller. Doesen't show the wiring harness.
  8. Re: Handsfree kit mounting
    Dec 2009
    14 Post(s)
    I would be taking the radio out and seeing how much room there is.
    I would imagine the drawers are plastic so no problem drilling them.
  9. Re: Handsfree kit mounting
    Mar 2008
    Brydo I had a mki9200 in my Passat B6 and I agree it is hard to locate. I bought a Brodit clip that went over the centre air vent.
    http://cgi.ebay.co.uk/BRODIT-PRO-CLI...item230cf5364e
    Tiguan CR140 Sport |PDC all round| RNS 510 and RSAP/Iphone Premium BT |
    To do list: RVC, MFSW, MDI, Running Boards
  10. Re: Handsfree kit mounting
    Dec 2010
    Right, the job is done! Took me about 30 minutes all in and about 25 of that was removing the previous glue and sticky pads from the screen and dashboard!
    So I pulled it off as it was about to fall off, decided to move it about 1" left as it's easier to see without being hidden behind the indicator stalk that way from the drivers seat - it is a little on the metal trim but not much and this way it keeps the wire pretty well hidden.
    Removed it and all the glue, resecured it completely with new pads and fitted - it's on there rock solid and doesen't move when you press it at one side.
    As for the mic - I found a clip from my old kit and fitted that to the headlining and secured the mic up there... big big improvement. I've linked up some photos below and also took one above the light switch... the kit I have is too high to fit in the space securely.
    The screen in its old location.
    The mic in its old location.
    The screen removed, what a mess.
    The screen above the light switch, not a good fit.
    The screen in potential new location - a lot better I think.
    The mic resecured... and again.
    The screen now secured solid in it's new location... and again.
    I also used some tape and secured the wires in behind the lower dash panels so they are completely out of sight. Some residue to clean from the dashboard that I'll do when I clean the interior - it's bloody snowing here again!
    Thoughts?
  1. Reasonable option whilst saving up for handsfree kit for A6
    By m/bikertom in forum In Car Entertainment
    Last Post: 07-01-2011, 12:11 AM
  2. Integral Bluetooth radio for A4
    By Gary M in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-03-2010, 03:45 PM
  3. Replies: 8
    Last Post: 13-05-2008, 04:40 PM
  4. Audi A3 Projektzwo body kit for sale 1996 to 1999
    By spaceboy1 in forum Audi A3 - Archive Topics
    Last Post: 11-01-2008, 07:15 PM
  5. Audi Handsfree Telephone kit / Television
    By slhejh in forum Audi A4 - Archive Topics
    Last Post: 21-09-2007, 10:55 AM
