Thread: Cruise Control Query - Manual Gears
Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
  1. Re: Cruise Control Query - Manual Gears
    #21
    Nov 2010
    Yorks, UK
    Quote Originally Posted by ScottyUK View Post
    Zafi -you can see the brake light reflected in your rear window? Is that bleed from the high level brake light? That should be sealed around the edge.
    Hmmmnnnnn........ good point. Under normal (manual braking) driving I never see it, I can't remember how I came to see it in the mirror. It might have been as the wiper went past. I will have a play tomorrow
  2. Re: Cruise Control Query - Manual Gears
    #22
    Nov 2010
    Bury St Edmunds
    Quote Originally Posted by Cavokk View Post
    Actually there is more to the behaviour of the cruisecontrol on th b8 a4.
    Try to set it at ex 60 mph an then later on when you have stoped for the red light - prees resume when you are at slow speed, - then the cc will happily accelerate you up in the gears and you only have to stear and press cluch for changing the gears
    C
    I love this feature. I set the cruise and can drive my 75 mile journey to work with cruise on all the time. I use the button to slow down or speed up and change gear when the car tells me.
    A4 2.0 TDi S-Line Executive 170PS, Phantom Black, 19" Double Spoke Alloys, Xenon Lights, Parking System Plus, HDD Sat Nav, Phone Prep & Heated Seats
    MODS
    Needle Sweep, Lap Counter enabled, S4 Mirrors. RS5 Pedals
  1. How To retro fit cruise
    By a8 tech in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-03-2010, 01:34 PM
  2. AWX A6 Cruise control..
    By davebp in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-07-2009, 11:08 AM
  3. Retrofit Cruise Control
    By trainer555 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-06-2009, 09:15 PM
  4. Passat TDI 170 Cruise Control Fault
    By passat170 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-11-2007, 07:33 PM
  5. The new Audi A6 Avant
