Thread: Cruise Control Query - Manual Gears
Results 11 to 20 of 22
  1. Re: Cruise Control Query - Manual Gears
    The clutch pedal has a position sensor - rather than a switch, so now the car knows how far the clutch is depressed. Used for Hill Hold/Electric handbrake release and cruise control.
    Clutch down will hold Cruise Control (for changing gear) but clutch up in neutral will release Cruise Control - the engine senses that no torque is being demanded.
    MY2009 A4 Saloon 2.0 TFSI quattro S-line Exec - Aruba Blue, 19" alloys, Convenience Key, Sunroof, Adaptive Lights, Anti-dazzle Folding Mirrors, Rear Sun Blind, Heated Full Leather with Memory, Storage/Light Packs, Audi Hold Assist, Adaptive Cruise Control, Parking System Advanced, Privacy Glass, Rear Airbags, TPMS. MMI 2G with B&O Sound System, DAB Radio, DVB TV, AMI and Bluetooth Phone prep High with Privacy Handset.
  2. Re: Cruise Control Query - Manual Gears
    You could also argue that its preventing excessive wear on the gearbox as modern teaching is to not use the gears to slow down but only the brakes.
    I took the IAM test a couple of years ago and found it very difficult to get out of my old habit of occasionally slowing by changing gear. Now trying to observe the IAM driving style, I like the cruise/clutch set up on the B8.
    2015 Floret silver A3 Sportback 1.4 TFSI Sport 150 COD
    2005 Liquid Blue A3 Sportback 2 litre FSI SE
  3. Re: Cruise Control Query - Manual Gears
    Jan 2009
    Essex
    I can't see IAM every being compatible with Cruise Control
    MY2010 A4 Avant 2.0 TFSI quattro S-line Exec - Aruba Blue, 19" alloys, Full Leather, B & O, 3G Tech Pack, Adaptive Lights, Dynamic Susp, Folding Mirrors, Power tailgate, Storage/Light Packs, Parking Plus, Heated Seats, Rear Blinds, Load Rails, Privacy Glass, Rear Airbags, TPMS, Load Liner
    Gone : 09 A4 Avant, B6 S4, TT, Golf GTi...and the rest are embarassing!
  4. Re: Cruise Control Query - Manual Gears
    Dec 2009
    Europe
    Actually there is more to the behaviour of the cruisecontrol on th b8 a4.
    Try to set it at ex 60 mph an then later on when you have stoped for the red light - prees resume when you are at slow speed, - then the cc will happily accelerate you up in the gears and you only have to stear and press cluch for changing the gears
    C
    A4 B8 phantom black
  5. Re: Cruise Control Query - Manual Gears
    Feb 2010
    United Kingdom
    But surely the revs rise as you put your foot on the clutch to change gear if its holding the throttle position??
    B7 S4 Avant Moro Blue, TIP, Auto lights/wipes, Sat Nav, Cruise, DRL'S.
  6. Re: Cruise Control Query - Manual Gears
    Jan 2009
    Essex
    Nope - remember the throttle's fly by wire of the computer takes care of it.
  7. Re: Cruise Control Query - Manual Gears
    #17
    Nov 2010
    Yorks, UK
    Its also the first car I have driven where the cruise control applies the brakes to keep the speed constant when going down a hill.
    I thought it had amazing engine braking until I saw the brake light reflected in the rear window
  8. Re: Cruise Control Query - Manual Gears
    #18
    Feb 2010
    United Kingdom
    Quote Originally Posted by Zafi View Post
    Doesnt all cruise work that way though?
  9. Re: Cruise Control Query - Manual Gears
    #19
    May 2008
    Quote Originally Posted by Jason.S View Post
    Not at all. I had a 2008 A6 which braked with cruise on to stop speed increasing when going downhill etc, now have a 2010 Passat which doesn't, so it will pick up speed if the hill is steep and/or long enough.
  10. Re: Cruise Control Query - Manual Gears
    #20
    Jan 2009
    Essex
    The braking caught me out the first time it happened. A bit of surprise when the previous two Audi's relied on engine braking.
    Zafi -you can see the brake light reflected in your rear window? Is that bleed from the high level brake light? That should be sealed around the edge.
  1. How To retro fit cruise
    By a8 tech in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-03-2010, 01:34 PM
  2. AWX A6 Cruise control..
    By davebp in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-07-2009, 11:08 AM
  3. Retrofit Cruise Control
    By trainer555 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-06-2009, 09:15 PM
  4. Passat TDI 170 Cruise Control Fault
    By passat170 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-11-2007, 07:33 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
