Thread: VW Passat - Snapped cambelt VW Passat TDi BMR Engine
Results 1 to 10 of 10
  1. VW Passat - Snapped cambelt VW Passat TDi BMR Engine
    Jan 2011
    Luton
    Could do with some advice, A friend has changed the cambelt on a Passat TDi BMR engine and about a week after the tensioner come off. It had pulled the stud out of head and snapped all the rockers.
    £900 later he has re built complete head and fitted another new belt kit. Took ages re timing and making sure everything was torqued etc.
    Car ran perfect for 2 weeks, but customer has just called him from side of motorway and the belt has come off/snapped again.
    He is a city and guilds mechanic who normally does not have problems, he has used correct tools and also gone by Autodata to set timing etc.
    Can anyone give him some advice as to where he may be going wrong or if there is some special thing with this engine.
    He really can not afford to ruin another head.
    Any help really appreciated
    Alan
  2. Re: VW Passat - Snapped cambelt VW Passat TDi BMR Engine
    135 Post(s)
    2043 Post(s)
    Without seeing it, it is hard to. I did see this happen once before and someone had misinterpreted the Autodata spec of 20Nm + 45° (the VW spec is “20 Nm and 45° (1/8 turn) further” as 20Nm + 45 Nm which pulled the stud out of the head. If the failure is the same it may be that the repair to the stud location (typically a Helicoil or Time Sert insert) has failed.
  3. Re: VW Passat - Snapped cambelt VW Passat TDi BMR Engine
    Norfolk
    Waterpump siezed ?
  4. Re: VW Passat - Snapped cambelt VW Passat TDi BMR Engine
    135 Post(s)
    2043 Post(s)
    If it is not the tensioner stud this time.
  5. Re: VW Passat - Snapped cambelt VW Passat TDi BMR Engine
    Jul 2007
    Quote Originally Posted by a1carparts View Post
    Alan
    Yep, mine did this the day after having the cambelt done.
    The single (!) tensioning bolt has a very fine thread screwing into an alloy head - the engineers where mine went to be refurbished and helicoiled had apparently seen several.
  6. Re: VW Passat - Snapped cambelt VW Passat TDi BMR Engine
    Mar 2009
    Sleaford, Lincs, UK
    Quote Originally Posted by martin1810 View Post
    Waterpump siezed ?
    Could this make the engine start sluggish when car not used for a while?
    07 Passat SEL Sport TDI 170 R
    Deep Pearl Black
  7. Re: VW Passat - Snapped cambelt VW Passat TDi BMR Engine
    135 Post(s)
    2043 Post(s)
    If the water pump seizes on an engine where the cam belt runs the pump, the engine is damaged instantly and will no longer run.
  8. Re: VW Passat - Snapped cambelt VW Passat TDi BMR Engine
    Quote Originally Posted by angus View Post
    Helicoil = Weak!
    Time Sert = Strong!
    Time Sert is difficult to get hold of (I think only Wurth sell it?) but is just so much a better & stronger system! You do need to RTFM before using it mind!
  9. Re: VW Passat - Snapped cambelt VW Passat TDi BMR Engine
    135 Post(s)
    2043 Post(s)
    Time Serts are not perfect, I have a full metric kit that I bought from Wurth but I have seen Time Serts crack and fail but they are better than a Helicoil in most instances.
  10. Re: VW Passat - Snapped cambelt VW Passat TDi BMR Engine
    Totally agree with you Crasher & to be fair, nothing is perfect, not even new heads!
    The Time Sert kits fail mainly if they are not installed correctly, hence my RTFM comment!
  1. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  2. Audi covers new ground with 2010 q7 suv
    Last Post: 15-04-2009, 08:08 PM
  3. Vw Passat 90 Tdi Ahu (2000 W) Engine Required
    By davejcb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-05-2008, 12:45 PM
  4. Intense TDI power - The Audi A3 TDI clubsport quattro
    Last Post: 18-05-2008, 10:12 AM
  5. passat tdi engine codes dilema.
    By passat>sport in forum New Member Introductions
    Last Post: 13-09-2007, 09:37 PM
