Thread: Fans and Climate Control
  1. Exclamation Fans and Climate Control
    May 2007
    Poole
    Apologies if this is elsewhere. I have an A6 Avant 2.7T Q (2001) everything is fine, but when the climate control is on, the auxiliary fan operates all the time. As soon as I push the Econ switch they turn off.
    This really isn't a problem unless you are outside the car - it makes a real din - there seem to be a huge number of fans under the bonnet!
    Is this normal - the car has always done it and the dealer assured me that it was normal - is this true?
    Julian Whitehead
    2001 A6 Avant 2.7T Q
    Swing Unlimited | www.subb.co.uk | www.myspace.com/swingunlimitedbigband
    They are noticeable but they shouldn't be overly loud. Check the bearing isn't dry.
  3. Thanks
    May 2007
    Poole
    Thanks Niall, this is what I thought.
    Will get it checked at next service time...
    Julian Whitehead
  1. A6 climate control / air con
    By Oakstedge in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-07-2009, 10:14 PM
  2. Cruise Control / Climate Control
    By Cian_ie in forum Archive posts
    Last Post: 27-01-2008, 08:47 AM
  3. Climate Control Too Hot
    By andrew hume in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 06-03-2007, 11:18 PM
  4. Climate Control – Fans won't stop
    By stasiak in forum Archive posts
    Last Post: 31-12-2006, 06:39 PM
  5. Climate control?
    By El Dingo in forum Audi A4 - Archive Topics
    Last Post: 01-07-2006, 11:38 PM
