Thread: Replaceing fan brushes - see photos
Results 1 to 10 of 14
  1. Replaceing fan brushes - see photos
    Nov 2008
    Hi, I am replacing the fan brushes on my A4 (2002, 1.9TDi) and am needing some help.
    I have removed the fan motor but can't see the fan brushes, I'm guessing I need to remove the black fan part from the motor but cant figure out how to seperate them?
    Any help will be greatly appreciated.
  2. Re: Replaceing fan brushes - see photos
    Cork
    I would imagine you have to split the motor to access the brushes. Or they slide into the side of the motors and would be held in by large grub screws.
    AUDI A4 Avant 2.0TDI S Line
    | My Slipper |
  3. Re: Replaceing fan brushes - see photos
    Nov 2008
    Hi Defsix, thanks for your reply.
    I cant see any grub screws etc so I'm thinking I might need to crack the plastic to remove it and access the brushes.
    I was reading in a forum elswhere that some fan motors dont have brushes? I'm guessing that that might be newer models.
    On a seperate note, I just realized that my title says 'see photos' and there arent any - oops! I was having problems bluetoothing them to my Mac, will try again later.
    Thanks again
  4. Re: Replaceing fan brushes - see photos
    Nov 2008
    bump
  5. Re: Replaceing fan brushes - see photos
    Nov 2008
    Hi, managed to get the photos uploaded if that makes things any clearer. Been looking at it again this morning and I'm really stuck - tried to prize it open but the thing is sold!!!
    If anyone has any ideas then please please please post a reply as really want to get this fixed as it is freezing!!!! he he.
  6. Re: Replaceing fan brushes - see photos
    Cork
    If I'm not mistaken the brushes are the six contact points that all point to the shaft on the top of the pcb. Are you sure they are replacable? do you have the new ones ?
    | My Slipper |
  7. Re: Replaceing fan brushes - see photos
    Nov 2008
    Hi, from what I have read on another thread you can replace be brushes, see link below:
    https://www.vwaudiforum.co.uk/forum/s...+brushes+guide
    I bought new brushes off ebay similar to these ones
    http://cgi.ebay.co.uk/AUDI-A3-A4-Hea...item3effbd4f75
    To be honest, I've never even heard of fan brushes before so I'm going by what I read on the above thread (along with a few others) to avoid replacing the fan motor.
    All the guides I have read tell you exactly how to remove the fan motor and then just to replace the brushes so I thought it would be obvious once I had the motor in front of me but unfortunately it isnt!
    Thanks again mate
  8. Re: Replaceing fan brushes - see photos
    Cork
    That appears to be from the B5 platform. This person on Audi Sport Network appears to be having the same problem. Again there is a B5 motor shown, however it appears to look a little different to yours, a B6 (I presume) . Are you sure they are the same ? Can anyone else confirm this with etka /elsa ?
    | My Slipper |
  9. Re: Replaceing fan brushes - see photos
    Nov 2008
    Doh! yes, it is a B6 that I have.
    I've looked at that many threads that I never noticed it was from a B5. If anyone has any bright ideas to avoid buying a new motor (£££) then it would be good to hear from you.
    Thanks again for your help mate
  10. Re: Replaceing fan brushes - see photos
    Not familiar with the B6 motor but on a B5 / B5.5 once you've got the motor out of the car then you need to open it up. There are 3 small black rubber stoppers on the outside of the motor. Press these in with a screwdriver etc and then the 2 parts of the motor will pull apart. You'll then see 2 small stainless clips. The brushes are behind these clips. (there's also a spring which pushed the brushes into the commutator of the motor - these springs will ping out when you pop the clip off so make sure you catch them!)
  1. Please Help Cooling Fan Problem
    By Sloggs in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-09-2010, 08:59 PM
  2. Air con fan rumbling.
    By Mike McKinstry in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-08-2010, 10:57 AM
  3. Please Help Sharan loss of cooling fan
    By andrenb in forum Touran - Sharan - Caravelle
    Last Post: 09-05-2010, 12:26 PM
  4. Heater not working
    By Nbaddy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-02-2010, 10:45 PM
  5. Fitting new brushes to both fans
    By muddy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-12-2009, 07:44 PM
