Thread: Where do I put the GPS antenna?
  1. Smile Where do I put the GPS antenna?
    Sheffield, UK
    Just taken out my old head unit to be replaced by a RNS510, can I put the GPS antenna under the dash or is it better on top?
    This is all I can see at the moment.... and it's dark outside
  2. Re: Where do I put the GPS antenna?
    May 2010
    Devon England
    hi mate you can put them under the dash as long as its not under anything metal, in my mk5 i put mine in front of the tray on top of the dash, as i could get the wire out but so you can see it, hope this helps mate
  3. Re: Where do I put the GPS antenna?
    Sheffield, UK
    Thanks I'll try and find a way through the dash :-)
  4. Re: Where do I put the GPS antenna?
    Mar 2008
    In my Passat I stuck it top right of the windscreen and it picked up reception excellently, as there is no tray like in the Golf. In the Tiguan, I have put it on the inside of the wing on drivers side (accessed by the fuel box on drivers side, and the reception is equally as good.
    Tiguan CR140 Sport |PDC all round| RNS 510 and RSAP/Iphone Premium BT |
    To do list: RVC, MFSW, MDI, Running Boards
  5. Re: Where do I put the GPS antenna?
    Sheffield, UK
    Quote Originally Posted by redrolo View Post
    Hi, thanks for the reply.
    Did you have to take the dash apart to feed the cable on the passat or is it possible to feed the cable through various holes without doing this?
    Nick.
  6. Re: Where do I put the GPS antenna?
    Mar 2008
    Nick,
    No need to remove the dash. I took the fuse cover off (right hand side), unclipped the cubby box (in line with your right knee) and fed it through to the radio this way. I didn't need to get any of the dash out, and was quite straight forwards.
    Hope this helps.
    Rich
  1. Question Two radio antenna cables.
    By geirkh in forum Golf MK5 - 2004 - 2009
    Last Post: 05-09-2010, 10:23 AM
  2. Mk3 Golf antenna cable
    By approvedlunatic in forum In Car Entertainment
    Last Post: 27-02-2010, 01:39 PM
  3. Removing Sharkfin antenna on a saloon
    By eccizz in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-11-2009, 10:14 PM
  4. How To Set up speed cameras on GPS on WD6050
    By lynneluke in forum In Car Entertainment
    Last Post: 05-07-2009, 06:41 PM
  5. Replies: 5
    Last Post: 24-05-2009, 11:57 AM
