Thread: How to check for worn or bad camshaft 2003 a4 b6 1.9tdi
  1. Exclamation How to check for worn or bad camshaft 2003 a4 b6 1.9tdi
    Jan 2009
    Im in the process of saving to get the tbelt clutch and flywheel replaced at the moment and i also wanted to check to see if camshaft is ok can anyone tell me if this is something i could do myself or if not how much should i expect it to cost if i took it to a garage. Id like to know this before i bring to get the work done so if there is something wrong there i can try to get it sorted at the same time. My tech level with cars is not great by the way so i would not tackle if it involves anything too technical
    A4 Quattro 1.9 tdi
  2. Re: How to check for worn or bad camshaft 2003 a4 b6 1.9tdi
    Apr 2009
    Replacement of a camshaft kit requires a high level of engineering
    skill, knowledge and special tools.
    If you suspect the cam or rockers are failing, because of a knocking
    sound or a drop-off in performance or an oil starvation issue, then
    you can remove the rocker-cover and look for scraping marks where
    the lobes meet the rockers. Post pics here.
    Regards
    Jim
  3. Re: How to check for worn or bad camshaft 2003 a4 b6 1.9tdi
    Jan 2009
    Quote Originally Posted by yaman View Post
    Regards
    Jim
    Cheers for the advice mate i wont go near it then. Reason i think there might be somethin wrong with the cam is because my brother went to look at an a4 avant 2.5tdi v6 a few weeks ago and it had rough idle and the guy went and got it checked and it turned out to be worn cam and the price tag to fix was scary. Im gettin the clutch timing belt and flywheel replaced and id be fairly disgusted to find out afterwards that the cam was worn too. If the cam was worn i would not even bother gettin the other work done. Is the rocker cover easy to take off. I have a socket set and two hands so if theres nothin too complicated about it i would take off and take some pics and post them
    A4 Quattro 1.9 tdi
  4. Re: How to check for worn or bad camshaft 2003 a4 b6 1.9tdi
    Apr 2009
    They are two completely different animals, and if that's the only
    reason you have, then you can relax, use the proper oil and
    sleep easy.
    But we do like to see photos of engine parts here.........
    Regards
    Jim
  5. Re: How to check for worn or bad camshaft 2003 a4 b6 1.9tdi
    Jan 2009
    sleep easy.
    Regards
    Jim
    No prob mate Thing is i bought this car with 120000 on it so im not sure if the correct oil has been put in it. It does burn oil not much i think and black smoke on heavy acceleration which i know is unburnt fuel or maby partly due to a remap done before i got the car. How awkward is it to remove rocker cover... do the bolt have to be tightened to a certain tightness and also removed in a certain order or something like that?
    A4 Quattro 1.9 tdi
  6. Re: How to check for worn or bad camshaft 2003 a4 b6 1.9tdi
    Apr 2009
    Quote Originally Posted by nickeym1 View Post
    Think your chasing a ghost here..... but if it keeps ya happy.
    120k is nothing
    Black smoke; could be remap, run injector cleaner through it and
    check air filter.
    Rocker cover; nice easy job. Remove and tighten from the centre out,
    left then right on opposing sides, and repeat with all 12 bolts, no need to
    over-tighten, because its a rubber gasket, and you could ring the threads
    on the alloy head!!! Remove breather-pipes. It will all make sense when
    you take the engine-cover off.
    Regards
    Jim
  7. Re: How to check for worn or bad camshaft 2003 a4 b6 1.9tdi
    Jan 2009
    120k is nothing
    check air filter.
    Regards
    Jim
    Your probably right mate but i would have some peace of mind if i took a few pics and got some feedback. Ill give it a try tomo weather permitting and get back to ya with pics. Appreciate the help bigtime
    A4 Quattro 1.9 tdi
  1. 1.8T Common Troubleshooting Guide
    By blacksline in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2010, 12:17 AM
  2. EML comes on every few weeks with 3 errors
    By Dark Horse in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-06-2010, 07:37 PM
  3. Ultra-economical audi a4 tdi gets the ‘e’ treatment
    Last Post: 11-07-2009, 08:11 PM
  4. Will 2008 Rs4 Steering Wheel Fit My Audi A4 2003 B6 Model?
    By audisingh in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-05-2008, 08:03 AM
  5. Will 2003 cabriolet leather seats from fit my audi a4 2003 b6 model?
    Last Post: 19-05-2008, 11:19 PM
