Thread: Allroad - Changing Front Air Springs
Results 1 to 10 of 14
  1. Allroad - Changing Front Air Springs
    Co Durham
    The front nearside airspring on my 2002 Allroad keeps lowering off. How much of a job are they to change? Thanks
  2. Re: Allroad - Changing Front Air Springs
    Ayrshire, Scotland
    18 Post(s)
    Quote Originally Posted by WesleyP View Post
    Similar steps to changing a spring except it has an airline going to it,
    The toughest part can be the top pinch bolt, plenty of loosening agent as if never removed preiously, it will be stuck, many reported breaking them which opens a whole new can of worms. take your time on the top bolt and hopefully it comes free.
    loads of info on this forum on changing the air springs, use the search function here is one for starters: https://www.vwaudiforum.co.uk/forum/s...oad+suspension
    read all the posts as there is some usefull info there,
    I would recomend the replacement unit from Arnott, a lot cheaper than from an Audi Dealer, and good quality.
    before all that though, is it definately the airblader leaking?? try soapy water on it to proove before spending £££'s
    regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  3. Re: Allroad - Changing Front Air Springs
    G3off Guest
    I changed one side this weekend,it took 2.5Hrs (including 4 cups of coffee), hardest part was holding the top 18mm nut with pipe grips whilst undoing the shock with an Allen key, all done on my drive in the lovely January fresh air.
  4. Re: Allroad - Changing Front Air Springs
    Oct 2010
    Potters Bar
    Lovely fresh January air...lol
  5. Re: Allroad - Changing Front Air Springs
    Ayrshire, Scotland
    18 Post(s)
    I recommend an 18mm deep cranked ring spanner for the top of the shock, as G3off, its difficult without one, read the other posts in the link and use the search function, as it is all detailed there.
    regards
    Andy
  6. Re: Allroad - Changing Front Air Springs
    Co Durham
    Thanks Gents - is there a procedure available anywhere?
  7. Re: Allroad - Changing Front Air Springs
    Jan 2010
    lancaster lancs
    Hi some good advice above. Just done this myself last weekend. Pinch bolt will be stuck! I had to take the whole unit off to get it on a bench and drill the critter out. Took hours and ended up changing all the suspension arms whilst i was at it. Hope yours is easier!
    To add to the nut on top of the shocker bit i used an old cheap socket and grinded 2 sided off flat so that i could hold it with a spanner, then you can use a normal hex through the middle of the socket.
    The Arnot bags are great. Really well put together and come with good instructions. Bought mine from ebay from germany and got great service. £260 incl delivery
  8. Re: Allroad - Changing Front Air Springs
    Jun 2010
    Derby
    I have read somewhere that the Arnot bags carry a lifetime warranty?
    2003 allroad 2.5TDi (AKE Engine)
    2007 Avant 2.0Tdi (BRE Engine)
  9. Re: Allroad - Changing Front Air Springs
    Ayrshire, Scotland
    18 Post(s)
    Quote Originally Posted by Mike Smith View Post
    Yes they are sold with a lifetime warranty from Arnott.
  10. Re: Allroad - Changing Front Air Springs
    Co Durham
    Tried and failed...I managed to snap the head off the pinch bolt trying to undo it...it was solid. Garage did it for me, they had to use heat to get it out damaging the ends of the two arms that the pinch bolt locates in position. However the total bill for an Arnott air spring, and fitting, including two replacement arms, was about the same as one OEM air spring from Audi.
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. Audi e-tron spyder hybrid study goes live in paris
    Last Post: 01-10-2010, 09:34 PM
  3. Replacing leaking rear suspension air bag - Audi Allroad
    By paul b in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-11-2009, 10:00 PM
  4. Question removal of air filter
    By DropKickMurphy in forum Golf MK3 - 1993 - 1999
    Last Post: 09-10-2009, 04:00 PM
  5. Greener New Generation Audi A3 Range Majors On Efficiency
    Last Post: 10-05-2008, 01:37 PM
