Thread: Sometimes Doors won't unlock now remote key fob is intermittent
Results 1 to 8 of 8
  1. Sometimes Doors won't unlock now remote key fob is intermittent
    May 2008
    Hi, Have had what seems like a "popular" prob with my 2002 Golf 1.6Se. Front passenger door often doesn't open remote or manually.
    However, now the remote key fob seems to need many clicks to get it to respond. Replaced battery, no difference!
    Also have loads of other things like back light on heater controls seems to go off when changing something on heating.
    Am starting to think there is some type of underlying electrical problem.
    Anyone have same problems or any ideas?
    I am no mechanic but can probably replace parts if I know what's wrong.
    Many thanks
    Andrew
  2. Re: Sometimes Doors won't unlock now remote key fob is intermittent
    May 2008
    Discovered that when I put the key fob right near the car door lock, the remote seems to function as normal.
    Does this sound like a problem with the key fob itself?
  3. Re: Sometimes Doors won't unlock now remote key fob is intermittent
    Dec 2007
    Belfast
    Get the car running, check and see if the door open light comes on or stays off when you go around the car systematicly opening and closing the doors and boot lid. . The reason for this is to determine if any of the door locks are duff. Let me know how you get on.
  4. Re: Sometimes Doors won't unlock now remote key fob is intermittent
    May 2008
    Did all that, light on dashboard showed doors as open when I went round and opened doors 1 by 1.
    Any ideas?
    Andy
  5. Re: Sometimes Doors won't unlock now remote key fob is intermittent
    Dec 2007
    Belfast
    This makes me think that the passenger door lock is faulty. To be totally sure, get a fault code read done to see if it shows up any stored faults.
    The locks are quite expensive, coming in at around £120.
    I recently had similar problems with my car, when the drivers door was closed, it was telling the car that it was open. Replaced the lock and everything was fine.
    Good luck !
  6. Re: Sometimes Doors won't unlock now remote key fob is intermittent
    May 2008
    Hi Mark, thanks for that . What is a fault code and how do I get one?
    Cheers andrew
  7. Re: Sometimes Doors won't unlock now remote key fob is intermittent
    Dec 2007
    Belfast
    You can get a fault code read done by any independant mechanic, in otherwords, check your local garage'mechanics and ask to they do diagnostics. Basically a computer that plugs into the car and the car will tell you if there are any active or stored codes/problems.
    Good luck !
  8. Re: Sometimes Doors won't unlock now remote key fob is intermittent
    May 2008
    Thanks Mark, Will look into it.
  1. Possible battery issue ??
    By Tay in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-12-2010, 07:45 PM
  2. Replies: 7
    Last Post: 11-11-2010, 10:13 AM
  3. Please Help Central locking works fine but remote doesn't
    By john_richter in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-04-2009, 02:46 PM
  4. how to program a 3 button fob for 01 passat
    By explorer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-01-2008, 04:43 AM
  5. key fob/ central locking/immobiliser problems
    By adamoliver in forum Polo - Derby - Lupo - Fox
    Last Post: 04-12-2007, 08:56 PM
