Thread: golf mk3 1.8 se starting problem
  1. Question golf mk3 1.8 se starting problem
    Jan 2011
    dudley west midlands
    when it is cold outside my golf mk3 1.8 se ADZ engine, does not start first time. when turning the ignition i get a whirring noise. if i turn off the ignition and try to start again it works fine. have recently replaced ignition coil, checked ht leads and dizzy. suspect battery or starter motor problem.anyone know for sure what it might be?
  2. Re: golf mk3 1.8 se starting problem
    Dec 2008
    Stockport
    The "whirring noise" is likely to be the starter motor turning but not engaging. I'd have to look up how VW starters work to take it any further. I can't remember if there are parts (pinion on starter being the likely one) that can stick or not move as far as they should.
  3. Re: golf mk3 1.8 se starting problem
    Jan 2011
    Thanks Bob, have been told that starter motors on this model are susceptable to dust from either the brake pads or clutch (cant remember which) getting into them. so maybe i will try and give it a good clean.
  4. Re: golf mk3 1.8 se starting problem
    Dec 2008
    Stockport
    Clutch dust would make sense. (Clutch is attached to flywheel which is where starter ring is.) Brake dust would be a hell of a problem.
  1. Golf GT 7DSG review after 6,500 miles
    By slo007 in forum Golf MK6 - 2009 - 2013
    Last Post: 14-11-2010, 12:05 PM
  2. Golf Mk3 not starting, no fuel - ECU problem?
    By ProDave in forum Golf MK3 - 1993 - 1999
    Last Post: 02-11-2010, 04:43 PM
  3. Please Help Very unusual Mk3 Golf Electric window problem
    By RyanMk3 in forum Golf MK3 - 1993 - 1999
    Last Post: 21-10-2010, 06:37 PM
  4. Please Help mk3 golf 1.8 se starting problems
    By BugBit in forum Golf MK3 - 1993 - 1999
    Last Post: 15-06-2010, 10:06 PM
  5. Question VW Golf TDi problem starting from warm!!! Help?
    By bennyboyca in forum Golf MK4 - 1999 - 2004
    Last Post: 19-10-2009, 02:36 PM
