Thread: steering angle sensor
Results 1 to 10 of 17
  1. steering angle sensor
    Dec 2010
    wales
    ive just replaced the rack on my a3 1.8t now all of a sudden the abs light has come on, ive had the car put on vagcom and it says the is a fault with the steering angle sensor anyone tell me what this !! and where it is and why has it come on
  2. Re: steering angle sensor
    The steering angle sensor is mounted on the steering shaft. ... It counts the steering-wheel revolutions accordingly,what is the reading of the fault ?you probably just need to calibrate it
  3. Re: steering angle sensor
    Dec 2010
    wales
    Quote Originally Posted by kenney View Post
    why would this bring on the abs light !!! i will find out exactly what it said i just need to speak to my mate with the vagcom, how do i calibrate ???
  4. Re: steering angle sensor
  5. Re: steering angle sensor
    May 2010
    Devon England
    the steering on the A3 and golf is a massive amount of info you have the angle sensor on the column and the torque sensor on the neck of the rack, now to set your angle sensor iirc you hold the steering wheel in the dead ahead pos then turn full left hand down and hold, then right hand down to lock, hold then dead ahead, if the light is still on drive in a straight line at about 10mph that should put the light out, the reason the ABS light is on is due to the ABS, ESP and steering rack all sharing info, as soon as you set the angle sensor the ABS light will go out
  6. Re: steering angle sensor
    May 2010
    Devon England
    good link, i had to set mine as above due to having to set the torue sensor aswell after replacing my rack
  7. Re: steering angle sensor
    Dec 2010
    wales
    "IT GETS WORSE" i read an older post and someone said they had the same prob as me !! but there steering wheel was 360 degs out !! so i disconected the steering uj and turned the wheel 360 degs now the airbag light has come on !! arrrggggghhh .....any ideas please !!
  8. Re: steering angle sensor
    If you did not remove the battery terminal when you removed the airbag,there will be a fault logged in the control unit.Not quite sure what you mean,and the reason for it when you say you turned the steering wheel 360deg???????????
  9. Re: steering angle sensor
    Dec 2010
    wales
    sorry kenney, i just undone the steering uj at the bottom of the steering shaft turned the wheel 360 degrees and re-assembled, the reason i did this was i read an earlier post as this was the prob for him !!!
  10. Re: steering angle sensor
    Then there is a possibility you have destroyed the coil connector with the slip ring
  1. Steering rack sensor
    By Jack Frost in forum Golf MK5 - 2004 - 2009
    Last Post: 28-09-2010, 01:14 PM
  2. Steering problems on a mk5 golf
    By cass62 in forum Golf MK5 - 2004 - 2009
    Last Post: 12-04-2010, 06:49 PM
  3. Steering angle encoder - where is it??
    By rarefir in forum Golf MK6 - 2009 - 2013
    Last Post: 14-01-2010, 11:00 AM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
