Thread: 2.7T (2000) Front Disc Replacement
  1. Question 2.7T (2000) Front Disc Replacement
    Hello all. This is my first post. I've just bought a 2000 model 2.7T. The car is great, except the front discs are warped. I understand this is not that uncommon. Anyway, I've bought replacement discs and pads but could do with guidance or a "how to".
    I had a quick look and wasn't 100% sure, so thought this might be a good place to ask. Apparently, they don't do a Haynes book
    Many thanks for your time,
    Dan
    Anyone?
    There are options for what calipers you have either FN3, FNR G60 or HP-2 the method of retaining them is similair either Allen key or what audi call a ribbed bolf. You ID sticker in the boot may detail your calipers. Your remove these bolts/sliders and remove the disc, clean the mating surface, push the pistons in the caliper back, I crack open the bleed nipple to avoid fluid returning to the reservoir, refit new pads sgrings etc, top up the reservior with new clean fluid and do a quick bleed and secure. Check and double check then refit the wheel. If you can give me the engine and brake code on an email to Info@3DAssociates.co.uk I'll send you the appropiate pages. The torque for the ribbed bold is 190nm. Other calipers use slides refitted to 25nm and require a resetting tool to get the piston to go back. Many Many motor factors sell these. Regards Peter
  1. audi a4 year 2000 stereo replacement
    By bigalan000 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-05-2007, 10:27 PM
  2. Front Brake Disc Size for Bora TDI 115bhp?
    By Jugga in forum Bora - 1998 - 2005
    Last Post: 16-05-2007, 09:35 PM
  3. wanted front end parts 2000 x passat?
    By minty0_10 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-05-2007, 09:52 PM
  4. VR6 Disc Conversion for Golf 3
    By Alun in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-04-2007, 09:22 PM
  5. 6 Disc CD Changer
    By mr_moth in forum Chat - Completely Off Topic
    Last Post: 26-04-2006, 02:53 PM
