Thread: A4 2.0 TDI misfire under load
  1. A4 2.0 TDI misfire under load
    May 2008
    I have a 170,000 mile S line Avant Tdi 140 bhp which until recently has been running well, it has had the belts changed when needed, as well as the oil pump drive replaced. Last service was an Audi long life and it has had a recent service which was just oil and filter. It has had a re map at Performance Tourque about a year ago whihc improved this no end. Recently I have noticed a bit of a misfire/hicup when accelerating on the motor-way, or along roads when under load, say overtaking, when cruising on light throttle loads the car runs fine. Starting has been a bit hesitaint, but I put this down to the recent cold weather. I am fairly mechanically minded as I build old race cars, but donl't want to tinker with my everyday run about, plus most of it is electronic. I plan to change the fuel filter this week , but if this does not cure the misfire under load what should I be looking out for next?
  2. Re: A4 2.0 TDI misfire under load
    May 2010
    Devon England
    a fuel filter change is the first thing id do, if it makes no difference then it could be a number of things but if it was me id get a full VCDS code read done and go from there mate
  3. Re: A4 2.0 TDI misfire under load
    Jun 2010
    Kings Lynn, Norfolk
    i was going to say it could be a failing injector but i noticed you have a 140 bhp 2.0 tdi not the 170, i had what could only be described as a misfire under load prior to my injector failing
    170 bhp s line bose, cruise control, pdc, mfsw, flawless glossy black, Now hopefully reliable with it's new injectors
  1. New Audi A4 2.0TDIe
    By onemanparty in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-01-2010, 01:28 AM
  2. Ultra-economical audi a4 tdi gets the ‘e’ treatment
    Last Post: 11-07-2009, 08:11 PM
  3. Audi A4 range plots a new course
    Last Post: 12-05-2007, 08:34 PM
  4. ADVANCED NEW FOUR-CYLINDER PIEZO TDI ENGINE
    Last Post: 17-05-2006, 08:14 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
