Thread: Rcd300 - no cdc error
  1. Angry Rcd300 - no cdc error
    Sheffield, UK
    Sorry if this is in the wrong section, a friend has a 55 plate VW Passat Sport Saloon with a RCD300 CD Multichanger. The problem is it won't play any discs.
    The error on the head unit shows "NO CDC", the multichanger accepts the discs and the light briefly shows green to show the disc is accepted but nothing will play.
    That's all the info I have at the moment, if anyone has any ideas or you need anymore info please let me know and I'll ask.
    Many thanks,
    Nick.
  2. Smile Re: Rcd300 - no cdc error
    Sheffield, UK
    I took this video on my phone, it does the same with both original cd's and cdr's.
    It doesn't flash green like I was originally told so my guess is it's the cd changer at fault.
    http://www.youtube.com/watch?v=i1oRdQRUNzM
  3. Re: Rcd300 - no cdc error
    May 2010
    Devon England
    at first i thought it was a wiring fault, as in the lead wasnt connected properly but seeing that i would say its a fault with the changer, will it play the cd if its put in the headunit?
  4. Smile Re: Rcd300 - no cdc error
    Sheffield, UK
    Hi, thanks for the reply, yes it plays cd's inserted in the head unit.
    Nick.
  5. Re: Rcd300 - no cdc error
    May 2010
    Devon England
    ok thats good, first thing id do is remove the headunit and check the changer quadlock is connected to the headunit properly, if it is then it sounds verymuch like a faulty changer, if you know anyone with VCDS they can do a scan and fine what fault code for the changer is coming up
  1. EOBD II Error Codes
    By Keithuk in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 23-05-2017, 04:59 PM
  2. MMI High version 55.7.0 - error occurs...
    By richribbon09 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-02-2011, 12:09 AM
  3. Please Help RCD300 - MP3 - CD Error
    By 11Riviera in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-10-2009, 02:08 PM
  4. Replies: 0
    Last Post: 09-07-2009, 03:35 PM
  5. S3 Haldex error 65535 internal control module memory error?
    By merlin2002 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 16-06-2009, 09:08 AM
