Thread: knocking/rattle
  1. knocking/rattle
    Dec 2010
    congleton cheshire
    i have a 1.9tdi 130bhp 02 passat, its got a miss on idle, and when reved to approx 2,000-2,500 rpm theres a rattle/knock on the top end can any1 help me on this, the car runs fine untill it hits the rpm any help from fellow members would be a great help to me its doin my head in
  2. Re: knocking/rattle
    Norfolk
    A miss on idle is usually a faulty injector wiring loom. The rattle is more worrying. It could be a sign of cam/follower damage which might also cause the idle miss. Either way you need to get a code read and then look under the cam cover.
  3. Re: knocking/rattle
    Dec 2010
    congleton cheshire
    whould that explain the popping sound that i can hear around the air-box/ plannum chamber? could you ring or text me on 07523199032 many thanks paul
  4. Re: knocking/rattle
    Mar 2009
    Definite camshaft/follower problem. A valve is not opening/closing correctly which will give you the popping noise.
    Expensive job but can be done without the head off.
    I came in to this world with nothing and I've still got most of it left.
  5. Re: knocking/rattle
    Apr 2010
    Carms, S.Wales
    I repaired a similar problem with my friends 1.9tdi octavia. After removing the cam cover i found that the camshaft had worn through the follower. I removed the cams, cleaned it up, and replaced all the followers along with the camshaft. All of this was done without removing the head, and was a failry straightforweard job.
    He had the parts for it on ebay, and i think it cost less than £250 for the whole job.
    Jamie......
  6. Re: knocking/rattle
    Apr 2009
    If this has been caused by neglected oil changes and/or blocked oil-ways
    and oil pick-up, then you should run an engine flush through the engine
    now, rather than after doing the cam and followers. There's also a chance
    that it might clean-out a blocked tappet.
    Regards
    Jim
  1. Noise... what is it?
    By hmeah in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-11-2007, 01:12 PM
  2. Rattle from o/s/f
    By chrisdicka in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-05-2007, 11:59 PM
