Thread: a4 heater not working
  1. a4 heater not working
    Oct 2010
    Hull England
    can anyone tell me where the heater motor relay is located on my 99 a4 avant
    cheers Bri
  2. Re: a4 heater not working
    Birmingham
    7 Post(s)
    I dont know about this car but others dont normally use a relay as such they have a reostst which changes the speed of the motor. These get really hot and are normally under the front grill to keep cool. They do burn out and the different speeds on the heater may stop working. If all the speeds do not work check the fuse or pull the heater motor out and check it is free as they can sieze up. Sometimes a bit of wd40 sorts them out.
  3. Re: a4 heater not working
    Oct 2010
    Hull England
    thanks mike i just pulled the motor out and found the brushes worn so thanks again
    Bri
  4. Re: a4 heater not working
    dan2802 Guest
    Quote Originally Posted by blewis View Post
    Bri
    Buy the replacement brushes from ebay (£10).
    Changed mine on boxing day, took less than 1 hr.
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=200559029856
  5. Re: a4 heater not working
    May 2010
    Bristol
    Hi I have a 2004 A4 and yesterday my heater blower just suddenly stopped working the controls work and I can hear the vents changing but no aire blowing out. Any Ideas all I can find on ebay is heater blowers for upto 2001 nothing for a 2004 model. Also if the bushes have worn in mine will it be possible to use the 2001 bushes in mine?
    Thanks in advance Neil
  6. Re: a4 heater not working
    Birmingham
    7 Post(s)
    I would say check you are getting power to the motor first.Simple things like check the fuse and see if there is voltage at the motor end with a multi meter or even a bulb and a piece of wire will do. It should get higher voltage or the bulb get brighter the higher the speed you switch to. If that is ok then the motor is at fault. Brushes could be the problem or sometimes they sieze up. I cant imagine that they would have changed the motor design that much from model to model as there isnt the need to. The only variation may be if it is from a different manufacturer. My recommendation is email the guy selling them and ask him if they are for your car as he seems to know what he is on about.
  1. A4 heater directional air
    By gkm24 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-03-2010, 09:47 AM
  2. Please Help audi A4 rear lights not working
    By vbautris in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-01-2010, 06:33 PM
  3. New A4 S Line details
    By Brioss in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 02-03-2008, 06:35 PM
  4. Audi A4 range plots a new course
    Last Post: 12-05-2007, 08:34 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
