Thread: passat estate 2003 washer bottle removal
  1. passat estate 2003 washer bottle removal
    Dec 2010
    oldbury west midlands
    Hi everyone new member first post looking for some advice on removing the washer bottle from my 03 passat estate as it seems to have developed a leak during the cold weather.Thanx
  2. Re: passat estate 2003 washer bottle removal
    7 Post(s)
    Wheel off, wheel arch liner off, unbolt and remove bottle.
    More likely to be a split pipe from the bottle though than the bottle itself. The VW pipe is bad quality, replace with some clear pipe.
    I had to do this very repair.
    Note that that if it turns out to be the pipe, the length I replaced was from the pump to the joint to by the windscreen bottom corner. This runs partly through the chassis leg so draw the new pipe in on the back of the old as you remove it.
  3. Thumbs up Re: passat estate 2003 washer bottle removal
    Dec 2010
    thanx for your help not being much of a mechanic i appreciate your directions and will follow them closely.Cheers.
  1. B6 Estate multiple Trim removal
    By LeFrog in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-04-2010, 07:20 PM
  2. Question 2003 Passat Estate help needed
    By Tezzza in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-02-2010, 03:07 PM
  3. Please Help Audi A4 Washer Bottle Leak
    By Audichap in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-02-2010, 05:04 PM
  4. Replies: 0
    Last Post: 03-03-2008, 08:19 PM
  5. Replies: 0
    Last Post: 15-01-2008, 09:05 PM
