Thread: brake light switch
Results 1 to 10 of 15
  1. Question brake light switch
    w-s-m somerset
    hi,
    does any1 know where the brake light switch lives and how it fits??
    cheers.
    leicester
    On most cars it's above the foot brake peddle, normally it screws down to rest on the arm of the foot brake so when you depress the brake the switch opens to makes a circuit.
    w-s-m somerset
    Quote Originally Posted by jimbob View Post
    thanx 4 the reply jimbob. have found and changed the switch now but still having majour problems.....
    brake lights a permanently on even with ignition off!!
    leicester
    if you disconnect the brake light switch do the lights go out?
    w-s-m somerset
    yes, been back to vw for a second switch but still the same????
    leicester
    So when you disconnect the plug from the brake light switch the lights go out, if so then i think your not screwing the switch down enough you have to screw it down till it puts your brake lights out
    w-s-m somerset
    tried gettin the switch in, but struggle to get the switch to turn in the bracket. is there a nack to doin this?
    leicester
    is the switch a screw it type?
    w-s-m somerset
    it twists into a bracket but no screw thread.
    leicester
    hi found a link for you http://forums.vwvortex.com/zerothread?id=1158315
    this should help.
  1. Tailgate light switch
    By vertical2m in forum Archive posts
    Last Post: 08-02-2008, 05:30 PM
  2. brake light switch
    By jlo in forum Archive posts
    Last Post: 22-08-2007, 03:47 PM
  3. Only the high level brake light and flahing coil light
    By 49forever in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-05-2007, 04:41 PM
  4. 02 Audi A6 ESP/Brake light switch question
    By schoelman in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-12-2006, 11:44 PM
  5. mk 4 1.8t reversing light switch
    By cbrrocket6 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-11-2006, 12:47 AM
