Thread: Audi 80 1.9tdi - Missfire/Engine Cut
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: Audi 80 1.9tdi - Missfire/Engine Cut
    #11
    Aug 2008
    I've got the same cut out problem, injector cleaner helped for a while but its back. Any luck fixing yours?
  2. Re: Audi 80 1.9tdi - Missfire/Engine Cut
    #12
    Quote Originally Posted by rasdaz View Post
    Hi. Yep, got it fixed. It was the injector with the little microchip attached so presumably it was the chip malfunctioning. Had it put on a diagnostics machine first but nothing much showed up as the car is too old to display a comprehensive result and it was down to the engineer's experience in identifying the fault. Wasn't cheap, about £190.00 (checked the price online and that's what they cost) for the injector and £60.00 for the test and labour. But well worth it. Find an Audi/VW independant specialist if you can otherwise it'll probably cost a lot more at a main dealer. Good luck!
  1. 1.9tdi 110 engine life
    By Hector64 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-09-2009, 09:22 AM
  2. Replies: 13
    Last Post: 01-04-2008, 02:24 PM
  3. juddering or missfire
    By grumpyob in forum 80 - 90
    Last Post: 17-02-2008, 05:38 PM
  4. audi a4 1.9tdi engine code afn please help
    By mpep666 in forum Audi A4 - Archive Topics
    Last Post: 26-01-2007, 12:24 AM
  5. Passat 1.9TDI Engine Smoking
    By New2VW in forum Chat - Completely Off Topic
    Last Post: 18-07-2006, 04:45 PM
