Thread: 1998 a4 b5 high emmisions fail mot
  1. Exclamation 1998 a4 b5 high emmisions fail mot
    Dec 2010
    aberdeen scotland
    hi guys am new to this site after coming to a problem
    with my a4 emmisions being really high
    have been told loads of different things regarding
    to what it could be
    have been told faulty maf or map sensor /lambda sensor /cat?
    here is my results from the test
    its a 1600 se model
    1st fast idle test
    engine rpm 2450/2850 manual check not tested
    limits actual values results
    co % vol 0.30 0.85 fail
    hc ppm vol 200 138 pass
    lambda 0.97/1.03 0.99 pass
    2nd fast idle test
    co % vol 0.30 6.31 fail
    hc ppm vol 200 357 fail
    lambda 0.97/1.03 0.83 fail
    natural idle test
    co % vol 0.50 9.95 fail
    overall results test failed
    so this is the results can anyone point me in the right direction
    to what it could be before i fork out a load of money
    trying everything
    thanks in advance
  2. Re: 1998 a4 b5 high emmisions fail mot
    Apr 2009
    If your air-filter is clean, you need to get a diagnostic
    fault-read done, to point you in the right direction.
    Regards
    Jim
  1. Scottish members declare yourself
    By JR001 in forum Scotland
    Last Post: 17-02-2023, 09:12 AM
  2. T45e Hand scanner for 1998 B5
    By andysuth in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 29-09-2009, 09:02 PM
  3. b5 a4 avant quattro
    By eddy_p in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-05-2007, 09:44 PM
  4. Fast forward to spring with new A4 Cabriolet S line range
    Last Post: 02-02-2005, 09:26 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
