Thread: STOP - Brake Fault - Service Manual
  1. STOP - Brake Fault - Service Manual
    Jun 2010
    Ireland
    Got this warning the other day it will start beeping then display the warning and go away it never stays on and comes on intermittently. The ABS is working fine and no loss of performance of the brakes. Is this just something small like low brake fluid.
  2. Re: STOP - Brake Fault - Service Manual
    first thing is to check brake fluid first
  3. Re: STOP - Brake Fault - Service Manual
    May 2010
    Devon England
    as above check the fluid, then check the pads iirc the waring light wire is only on the n/s/f but id be tempted to check both sides, if the fluid is low and topping up puts the light out then id say your pads are very low
  4. Re: STOP - Brake Fault - Service Manual
    Merseyside
    Mine did this 2 years ago during the cold weather - it was just a case of topping up the brake fluid as it had dropped slightly when the pads had worn down. I think the cold weather may also cause the fluid to contract slightly?
    It is virtually impossible to see the fluid level through the reservoir on the Passat though!
  5. Re: STOP - Brake Fault - Service Manual
    Quote Originally Posted by Peter_HMR View Post
    I had this occur a few times this year, checked fluid level, ok, pads ok. I disconnected the plug from the level sensor and it has been fine since.
    Just check fluid level when you check oil level, coolant level, power steering fluid level etc. Its a crap system that relys on a zero signal for the fault condition, if the wire fails it should go into alarm condition! so its not worth replacing the level sensor.
    Jun 2010
    Ireland
    Is there any specific fluid I should use or does the quality have a big impact like with engine oil? Otherwise I can just top it up with any dot 4.
  7. Re: STOP - Brake Fault - Service Manual
    Jun 2006
    UK, Mids
    Any DOT 4 is fine, it is said to be better to but it from a popular shop that hasn't had it sitting around for years.
    Audi A8 - 2015 - 3.0TDI
  1. Audi A6 VagCom Scan Results.
    By cwilding in forum VCDS - Help Requests
    Last Post: 19-11-2010, 10:19 PM
  2. concert to rns-e tt 2007
    By wilburforce in forum VCDS - Help Requests
    Last Post: 16-09-2010, 09:53 AM
  3. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  4. dpf fault
    By deutsch in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-03-2010, 02:50 PM
  5. Help needed from experinced A6 owners
    By robmorphet in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-03-2010, 08:27 AM
