Thread: New Clutch and DMF, now clutch gone sloppy
  1. New Clutch and DMF, now clutch gone sloppy
    May 2008
    Northumberland
    Clutch was slipping has been for a while. Got it booked in and replaced clutch and DMF. Did around 50 miles (no probs).
    Drove into Newcastle city centre this evening and gear stick goes sloppy and can't select gears (nightmare). Managed to get into 3rd and drove home. Tried reverse, nothing there.
    Any ideas if there is anything I can do short term to get it to the garage or what should I be looking for.
  2. Re: New Clutch and DMF, now clutch gone sloppy
    May 2010
    Devon England
    iirc the selector is held on to the box with a 10mm or 11mm bolt it could well be thats loose, without looking underneath its a job to say for sure, did you hear any noise before you lost the gears?
  3. Re: New Clutch and DMF, now clutch gone sloppy
    May 2008
    Northumberland
    Hi Phil
    I didn't hear any noise.
    Once in a gear the car drives and pulls normally, does this mean that it a purely a selector problem?
  4. Re: New Clutch and DMF, now clutch gone sloppy
    Yes. You have a loose linkage. Regards Peter
  5. Re: New Clutch and DMF, now clutch gone sloppy
    May 2008
    Northumberland
    Hi Peter
    Can this be done top side, or is it back to the garage?
    Weather not too hot up here at the mo, bit snowed in so can't see the car getting back to the garage quick.
  6. Re: New Clutch and DMF, now clutch gone sloppy
    There is a fore and aft shaft and a rotational shaft. As they had the gear box off then I sustect they only disconnected at the Gearbox end to access is from underneath. If you want the drawing PM me or post up your email address with the year, engine and gear box code form the ID label in the spare wheel bay. Regards Peter
  1. New clutch DMF problems
    By waring192 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-09-2010, 07:09 PM
  2. Clutch / DMF time
    By A1Dan75 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-09-2010, 10:07 AM
  3. Clutch and DMF change required
    By ajmatu in forum Octavia
    Last Post: 20-03-2010, 02:53 PM
  4. Clutch and DMF
    By ali_a4_avant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-10-2009, 09:50 AM
  5. TDI Clutch & DMF Question
    By Audity in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-09-2009, 07:43 PM
