Thread: 01578 Airbag deactivation warning lamp error
  1. 01578 Airbag deactivation warning lamp error
    Jun 2010
    Derby
    my air bag light is on & off intermittently
    The code reads ..
    Passenger side (K145)
    009 open or short to ground
    anyone any idea where and what this could be ?
    2003 allroad 2.5TDi (AKE Engine)
    2007 Avant 2.0Tdi (BRE Engine)
  2. Re: 01578 Airbag deactivation warning lamp error
    Norfolk
    Has anyone been working on the dash recently. It probably is what it says, an open connection because a connector somewhere is causing it. Presumably you have the passenger airbag deactvation warning light. So that is the place to start.
  3. Re: 01578 Airbag deactivation warning lamp error
    Jun 2010
    Derby
    The only thing that springs to mind, I had a the rear washer hose come apart behind the front passenger kick panel, and I noticed a handful of relays there, wondering if the water penetrated there?
    It seems to be on more when cold, (roll on the warm weather!!!) I've turned the key switch off in the glove box and the light goes out, so I guess it would be before that, looks like a strip down when its a bit warmer, although the fault may well disappear then too !!
  4. Re: 01578 Airbag deactivation warning lamp error
    Norfolk
    Could easily be due to cold temps and condensation. An almost invisible layer of corrosion can cause these silly faults.
  1. Airbag Deactivation Warning Lamp
    By Mike Smith in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-12-2010, 10:48 AM
  2. A6 Airbag warning symbol after installing glove box
    By bdm2510 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-09-2010, 12:54 PM
  3. Replies: 4
    Last Post: 21-07-2010, 09:10 PM
  4. Passenger Airbag Deactivation Fault
    By jluckcuck in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 21-05-2008, 10:50 AM
  5. Airbag warning lamp ECU - £500
    By mlm in forum A2
    Last Post: 07-02-2008, 04:34 PM
