Thread: A6 Avant - water in the boot lid
Results 1 to 10 of 26
  1. Re: A6 Avant - water in the boot lid
    Jun 2009
    Cornwall TR12
    The problem is solved. It was water ingress via the nearside light cluster. The foam/rubber seal which should be stuck to the cluster had come away on one corner and was letting the rain in. After bottling out when trying to prise off the trim I booked it in to a local body shop - Autospray, Penryn. They located the problem, and while I waited fixed it (I hope!) for £24, can't say fairer than that!
  2. Re: A6 Avant - water in the boot lid
    Jun 2009
    Bexleyheath, England
    I am also getting this issue, especially after recent rain fall !! Can you tell me which rubber seal you replaced, so hopefully I can sort my one out. It is happening on the n/s so hoping its exactly the same problem.
    George
    1998 A6 Avant 2.5TDI AFB
    RETIRED @ 185K miles,
    2006 A6 Avant 3.0TDI BMK S Line Quattro retired due to RTC
    2009 S4 B8 Avant Stage 2 + DP EPL & TCU, big list of mods
  3. Re: A6 Avant - water in the boot lid
    Aug 2013
    Embra
    I have this too. Mine has a new bootlid fitted late last year by Audi as the old one rusted away. Audi said they couldn't find a fault and I found the grommets had been removed.
    Water also gathers at the base of the rear screen in mine, and then runs down the side into the boot or up my arm when I open the tailgate.
    Its on my list, one day...
  4. Re: A6 Avant - water in the boot lid
    May 2014
    Had same problem which water came in from near side light cluster ,boot all soaked and water went to DVD unit so close to fire them. cheap fix with clear sealant couple of quids, applied from inside boot, works great, no more leaking.
  5. Re: A6 Avant - water in the boot lid
    Jun 2009
    Cornwall TR12
    Hi Joe, if you remove the light cluster, you will see that there is a foam rubber seal which seals the cluster to the tailgate structure. It should be stuck to the light cluster, but on mine it had come away at one corner. The bodyshop used a little bit of silicone type sealant to stick the seal back to the cluster and no more water in the tailgate!
  6. Re: A6 Avant - water in the boot lid
    Jun 2009
    Quote Originally Posted by Audijager View Post
    So its the cluster on the tail gate that's leaking !! and not the actual light unit.
    George
  7. Re: A6 Avant - water in the boot lid
    Jun 2009
    Cornwall TR12
    Quote Originally Posted by joedredd View Post
    The light unit/cluster would have to be quite badly cracked to allow rain in directly. Looking from outside the car, obviously there is a gap around the light unit, between the plastic light cluster and the steel tailgate. The rain runs into this gap, so unless the seal (that you probably can't see unless you remove the light unit) is doing it's job, the rain can find it's way past the seal and into the tailgate.,
  1. Leaking saloon boot lid
    By g-black in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-09-2010, 06:43 PM
  2. Binding brakes ??
    By mini mik in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-07-2010, 09:54 PM
  3. Replies: 0
    Last Post: 23-02-2006, 02:26 PM
  4. The new Audi A6 Avant
  5. Ultimate specification for A6 Avant final edition models
    Last Post: 18-10-2004, 07:29 PM
