Thread: A6 Avant - water in the boot lid
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. A6 Avant - water in the boot lid
    Wonder if anyone else has/is experiencing the problem Audi seem unable to fix.
    My 57 plate Avant keeps suffering from water in the bootlid. When you raise the boot you can here the water sloshing around and then running out of the catch/courtesy lights.
    So far they have:-
    Refitted the washer pipe to the rear washer
    Fitted a mod kit to the pipe work where it passes through boot hinge
    Replaced the boot seal (don't know why as there is no ingress into thye boot itself)
    Replaced the high level brake light
    During the above taken out and refitted the tail lights
    ....... the only thing left is the seal from the rear window to the boot itself!
    Any suggestions on a cure as the warranty runs out in January!!!!
  2. Re: A6 Avant - water in the boot lid
    Jun 2009
    Cornwall TR12
    Did you resolve this? Mine is 9 months out of warranty and has just developed the same problem. I'm fairly sure it's caused by rain rather than the rear washer as the tailgate fills up after heavy rain when the car is parked.
  3. Re: A6 Avant - water in the boot lid
    Nov 2009
    46 Post(s)
    OP hasn't been on in 2 years, doubt he's coming back.
    Did you do another search, this has been discussed pretty recently, have a look through the section.
  4. Re: A6 Avant - water in the boot lid
    Jun 2009
    Cornwall TR12
    Thanks Chris, I read the first 20 pages and then searched. I'll keep looking!
  5. Re: A6 Avant - water in the boot lid
    Jan 2012
    West Yorkshire
    Open tailgate and look at the bottom edge should be two small black oval grommets, take them out, close tailgate onto 1st latch I.e not fully closed and leave for 10 or so minutes and water will drain out (you'll be able to see it coming out). Hope that helps you mate, worked on mine.
    Steve
  6. Re: A6 Avant - water in the boot lid
    Jul 2013
    77 Post(s)
    I don't have an Avant but i would recommend that you put a hole in the grommets that are mentioned above.
  7. Re: A6 Avant - water in the boot lid
    Jun 2010
    Manchester, United Kingdom, United Kingdom
    10 Post(s)
    I have had the same thing.... Your rear wiper will start misbehaving soon as water comes into the motor assembly.... If they replaced all that stuff they should have checked the hose at the motor itself.... I think that's where your ingress is.
    Audi A6 C7 Allroad 3.0 TFSI.
    Previous:
    Audi A6 C6 2.7TDI Le Mans.
  8. Re: A6 Avant - water in the boot lid
    Jun 2009
    Cornwall TR12
    I've removed the grommets as recommended and the remaining water has emptied. Although I'm not ruling anything out yet, I don't think it's connected with the washer because, a) the water is fresh, as opposed to my washer water which is heavily laced with fluid and b) the water ingress occurs when the car is parked and after rain. My next step is going to be removal of the trim and a good hosing whilst i sit inside observing.
  9. Re: A6 Avant - water in the boot lid
    Audijager ...... Audi did eventually resolve the problem, and like you it was water ingress and not the washer (although they did fit the 'recall fix' to this known problem as well!). Eventually they removed the rear screen and replaced it, along with all the seals, including rear light clusters. This did appear to 'do the trick' as the problem did not reappear. However, it didn't help another water issue I subsequently had .... but I guess driving too quickly through a flood can hardly be blamed on Audi .....!!!!!
  10. Re: A6 Avant - water in the boot lid
    Jan 2014
    Surrey
    Sounds like your best bet is to pray it doesnt rain...
  1. Leaking saloon boot lid
    By g-black in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-09-2010, 06:43 PM
  2. Binding brakes ??
    By mini mik in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-07-2010, 09:54 PM
  3. Replies: 0
    Last Post: 23-02-2006, 02:26 PM
  4. The new Audi A6 Avant
  5. Ultimate specification for A6 Avant final edition models
    Last Post: 18-10-2004, 07:29 PM
