Thread: Throttle Position Sensor? TPS??
  1. Throttle Position Sensor? TPS??
    Dec 2010
    Sunny Blackpool
    First post, so please bare with me!
    I was travelling home on Friday, some 150 mile journey and all motorway. About 50 miles in, travelling approximately 75mph, the car started to cough and splutter. The juddering and jerking got progressively worst until after another 10 miles down the road the car stalled with and engine management light one. I let my foot off the accelerator and reapplied, the car fired back in again. A little scarey in the fast lane over taking some lorries!
    I got the car home by accereating / letting off, as it wouldn't take 10% throttle,.. so cuising speed. Weird! People following me must have thought I was a loonatic!
    My mate stuck it on his diagnostics tool (not sure which one he uses), and it flashed out the Thottle position sensor, the only error code. He replaced the pedal, which I believe has the tps. All good over the weekend, but I didn't try the motorway..... until today! Same again, cutting out at 10% throttle, although again,.. it didn't start doing it until about 40/50 miles in. And again it was a progressive thing.
    Anyone got any ideas?
    Paul
  2. Re: Throttle Position Sensor? TPS??
    What is your engine code? It is on the white sticker in the spare wheel bay.
    The throttle position sensor is on the throttle body. Depending on your engine I think it may need a whole new throttle body.
  3. Re: Throttle Position Sensor? TPS??
    134 Post(s)
    2009 Post(s)
    Sounds like water in the plugs under the ECU, a common problem which gives the fault code you mention, I am just doing one at the moment.
  4. Re: Throttle Position Sensor? TPS??
    Dec 2010
    Sunny Blackpool
    I've had a look at the sticker in the spare wheel bay,... many, many codes...
    6021 13-6-6061 210 EN
    WAUZZZ8E Z 1A057350
    8E2 ONA
    A4 LIM TDI 1.9
    99KW MSS
    AWX _____ FEC
    LX72/LX72 N3A\LA
  5. Re: Throttle Position Sensor? TPS??
    Dec 2010
    Sunny Blackpool
    Thanks Crasher - sounds a simple one. I'll get my mate to take a look at that one. Where is the ECU by the way?
  6. Re: Throttle Position Sensor? TPS??
    134 Post(s)
    2009 Post(s)
    It is an AWX TDI engine. The ECU is in the box under the bonnet on the drivers side.
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. Replies: 21
    Last Post: 16-07-2015, 03:07 PM
  3. Throttle control problems with 2.6 V6
    By McSam in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-02-2014, 01:24 PM
  4. 1998 B5 - Hunting Idle after Throttle Body Cleaning
    By ectwo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2008, 05:53 AM
  5. Mk3 Golf TDI throttle position sensor
    By j_coupland in forum Golf MK3 - 1993 - 1999
    Last Post: 12-03-2006, 05:09 PM
