Thread: Red Diesel
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
  1. Red Diesel
    Northampton
    Whats the differance from normal diesel you buy at the petrol station and Red diesel that is used in farmers tracktors?
    would it do any harm to use it in a passat 130 pd engine?
    May 2007
    Liverpool
    As far as I know there is no difference apart from the red dye, before I got my Passat I had a fabia Vrs 130 bhp and I used red diesel (cherry ade I used to call it) for about 25,000 miles the only thing I noticed was a bit more smoke other than that it was fine.
    May 2007
    Just remember if you ever got your tank dipped with red diesel in it you could get your car seized. Seen it happen a couple of times.
  4. Smile
    SCARBOROUGH/GARAGE LOCATED IN PICKERING
    Quote Originally Posted by chrisvrscrx View Post
    Same stuff only with a dye added to alert customs and excise of its usage/place of origin,smoke is usualy attributed to the drums its transported in (empty gear oil drums etc) when transported from a site bowser to new recipient,if you pause to think about it - plant machinery can have a tremendous value,and a breakdown may induce a penallty cause for contractor concerned,so using inferior fuel than the stuff joe public fills his focus with at morrisons would be madness at best,cheers simon
    Oct 2006
    Sunny slightly hilly Norfolk
    Red diesel attracts a lower rate of duty for vehicles used OFF road, e.g. quarry vehicles. If you get caught using it on the road, its a minimum of £500 plus a recovery and storage fee. And it is increasingly likely you will, as Customs now have a lot of mobile testing teams. So the answer is DON'T use it. Its not worth it.
    2016 VW Tiguan Match Edition (Nimbus Grey) , 09 Ibiza 1.4 SE SC (Nayara Blue), 2014 Leon 1.2 SE (Candy White).
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    It's also an agricultural diesel, and different to pump diesel. I know of someone who had some in his pd130 fabia (leant it to his construction site worker brother for a week) and he needed a complete engine overhaul - new fuel pump, new fuel lines, 4 new injectors - Was over a couple of grand of work - For just one tank of red diesel....
    Jason - Rather mad Skoda Fabia driver.... Odd whiff of diesel coming from him.
    260bhp Skoda Fabia TDI Dyno Run
    http://www.youtube.com/watch?v=9BvjJjL7Z50
    315bhp Skoda Fabia TDI Dyno Run (2013)
    http://www.youtube.com/watch?v=TOE4nbT5NGY
  7. Red Diesel
    Quote Originally Posted by devonutopia View Post
    http://www.ybw.com/mbm/redalert/pdf/...l_campaign.pdf
    More or less identical (sulphur content and cetane rating can vary but not enough to damage a common rail engine) depending on suppliers,Im willing to put money on it that the fabia was filled with contaminated red,farm tanks etc are seldom clinicaly clean....
  8. Exclamation running on red
    north yorkshire
    Hi all, Dont do it red diesel or to give it it's correct name gas oil is a corser grade of fuel, it is taken out of the refraction process earlier than diesel and as such is not as refined. agricultural and plant vehicles have their fuel pumps etc adjusted to take the differences into account. normal road vehicles will run on red but it does wreak havoc over A SHORT time. in addition to the cost of repairs you are defrauding the VAT man and he's not one to upset having much more power than your standard TAX man, you would be risking large fines, payment of tax until you can prove you last bought white fuel, and POSSIBLE PRISON TIME.
    DAMAGE INCLUDES
    on old style engines
    worn injector nozzles/tips (expensive)
    wear inside the injector pump (very expensive)
    on new common rail
    worn pressure pump (very expensive)
    the smoking is caused by unburnt fuel which can destroy your cat and you'll need to change both of the above as well !!
    so if you run an old banger and don't mind prison food then the choice is yours (you still have to pay the fine and back tax upon release)
    if not don't risk it it will cost you more in the long run
    Mar 2007
    Ipswich, UK
    7 Post(s)
    A person I know 1st hand was caught using red diesel in his Transit van and the nice man from Customs & Excise not only relieved him of his van until storage and recovery was paid but he was also fined £3000.00!
    You have been warned, it's up to you if you take the risk?
    Northampton
    wont be using that stuff then, i was offered some for our diesel powered blower heater, looks like a rocket engine,
  1. Bio-Diesel anyone?
    By Huweth in forum Passat - Archive Topics
    Last Post: 14-02-2008, 02:32 PM
  2. Eos Diesel
    By louisg in forum Eos
    Last Post: 06-06-2007, 12:54 AM
  3. TT Diesel
    By A350BHPQUATTRO in forum TT - 8N Forum - 1998 - 2006
    Last Post: 07-05-2007, 12:18 AM
  4. diesel 130 bhp PD 25 mpg!
    By vw754 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-04-2007, 02:26 AM
