Thread: P0236 Fault Code Problem.
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: P0236 Fault Code Problem.
    Feb 2021
    Dartford
    Hi so I’ve got a mk5 golf gti 2006 coming up with the same code PO236 (turbocharger boost sensor) (G31) I have changed absolute everything including turbo and manifold to map sensor and wiring literally everything and it’s giving me the hump I’ve asked so many vw pages and no ones any help. Would anyone on here be able to give me some light to what it could be before I scrap the car😂 thanks
  2. Re: P0236 Fault Code Problem.
    1836 Post(s)
    4173 - Manifold Pressure / Boost Sensor (G31) P0236 00 [039] - Implausible Signal
    Does this come back immediately (what we call a hard code) or does it take some driving to make it appear? If it only comes back after driving I would suggest getting it pressure tested but you will need to find someone with the equipment.
  1. Retrofitted RNS-510, Changed GW, now a lot of errors
    By bjuran in forum VCDS - Help Requests
    Last Post: 09-07-2011, 01:37 PM
  2. cant find any modules fabia 1.9tdi
    By stevenpeck81 in forum VCDS - Help Requests
    Last Post: 26-10-2010, 09:42 AM
  3. dpf fault
    By deutsch in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-03-2010, 02:50 PM
  4. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  5. Check my scan
    By kite in forum VCDS - General Questions
    Last Post: 11-05-2009, 08:03 PM
