Thread: Dash Lights Illumination not working
  1. Dash Lights Illumination not working
    Northern Ireland
    Hi Guys, Its been a while since i posted here but i need someones help.
    I've recently had my golf garaged becuase of water leakage into the cabin, so it was carpets and seats out reseal the ancillaries carriers on the inner door card and reseal the fuse box under the scuttle. All a good job, so today i rebuilt the interior and hit the road only to find the dash illumination lights on the binicles and the heater controls are not lit. Everything works fine elsewise, i've checked all the relevant fuses in the fuse box and everything is A ok. I then decided to remove the switch just to check and i found it to be extremly hot to touch. I have it removed from the carnow. Just looking for some advice or anyone with any experience of this issue?
    Thanks for the help
    2001 Golf TDI S (ALH) Gone but never forgotten
  2. Question Re: Dash Lights Illumination not working
    Jan 2011
    London
    Hi there
    I think i have exactly the same problem, all the lights on the dashboard work, eg on the radio, speedometer
    , but just the heating, fan AC lights are not working for some reason.
    I have heard its to do with the wiring in the passenger side door but I am very unsure about this and could be way off.
    any help will be great though!
    thanks
  3. Re: Dash Lights Illumination not working
    Northern Ireland
    Sorry for taking so long to reply. I think your problem is just the bulb for the centre illumination. If you pull out the heater speed control know carefully using pliers and some soft cloth you'll see it in there. It will need to be carefully prised out of there using prob the pliers and some soft cloth. Do a search to see if you can find the best method.
    On another note i got my other issue sorted. Turned out the cig lighter wasnt connected correctly. Connected it all up and everythings working fine.
    Hope you get sorted mate. Let me know
  1. 99 tdi no dash lights turns over wont start
    By pg339 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-12-2013, 04:07 PM
  2. Question Touran trailer brake lights not working?
    By shakey036 in forum Touran - Sharan - Caravelle
    Last Post: 06-07-2010, 11:40 AM
  3. Replies: 4
    Last Post: 01-06-2010, 08:32 PM
  4. brakes stopped working coming upto the lights!
    By ritter1 in forum Golf MK3 - 1993 - 1999
    Last Post: 04-05-2009, 10:02 AM
  5. Re-setting Dash warning lights On Mk V5 Golf
    By AndyV5 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-06-2007, 05:50 PM
