Thread: Various Faults on A3 2.0tdi
Results 1 to 10 of 15
  1. Various Faults on A3 2.0tdi
    Dec 2010
    Ramsgate Kent
    HI all, new to the forum and owning an Audi.
    I am hoping someone can help me out here with advice on whats wrong with my new car that I love apart from the following.
    Recently purchased a 2004 A3 2.0tdi with some faults although I only thought she had fault one on purchasing.
    1, The open door switches on the driver door is not working so not getting the headlight on alarm when getting out and no puddle lights or door open light (passengers is fine). I assume this is just a lock swap out or is it connected to another fault?
    2, Now I assume that the 2 bottons on the driver door for the alarm sensors should light up when you press the buttons. Mine doesn't I dont know but possibly linked to the door lock micro switches?
    3, The car has an ipod denison installed but the concert does not seem to see it as a cd changer even when pressing the cd button once or twice.
    4, today whilst playing with the climate control it went off as in all the lights on it went out then they came back, also shortly afterwards the radio went off, came back on on second attempt at turning back on.
    Before picking her up she had a dead battery which was replaced so dont know if any of the fault codes i got on vag com are related to that but hopefully someone looking at this will now what my problems all relate to.
    Thanks in advance for any advice it will greatly appreciated as I want to enjoy driving my Audi even if its not a 2010 model.
    VCDS Version: Release 908.0
    Data version: 20090911
    Saturday,11,December,2010,18:40:11:13314
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
    VIN: WAUZZZ8P Mileage: 142270km/88402miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 FF HW: 028 101 190 5
    Component: R4 2,0L EDC 0000SG 6337
    Revision: 12345678 Serial number: AUX7Z0D5FNE0CW
    Coding: 0000072
    Shop #: WSC 06435 000 00000
    2 Faults Found:
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 000 - - - Intermittent
    Freeze Frame:
    RPM: 1344 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 10.56 V
    Bin. Bits: 11000100
    Bin. Bits: 11000000
    (no units): 1.0
    18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
    P1650 - 000 - - - Intermittent
    Freeze Frame:
    RPM: 399 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 10.56 V
    Bin. Bits: 11000100
    Torque: 0.0 Nm
    Torque: 346.0 Nm
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0023174
    No fault code found.
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
    Component: KlimavollautomatH12 0150
    Revision: 061925 Serial number: 8P0820043D
    Shop #: WSC 00000 000 00000
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 245
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    ON
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
    Component: Bordnetz-SG 1.0 H30 0501
    Revision: 00030000 Serial number: 00000000816553
    Coding: 01884F00A2141000000000000000000000
    Part No: 8P2 955 119 C
    Component: Wischer WWS Audi350 0180
    Coding: 16187408
    Shop #: WSC 00000
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
    Component: Airbag 8.4ED H00 0140
    Coding: 0011602
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
    Component: Lenksäulenmodul 012 0030
    Coding: 0000012
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 980 P HW: 8P0 920 980 P
    Component: KOMBIINSTR. VDO H71 0200
    Revision: D01 Serial number: 2245DD01000727
    Coding: 0004408
    Shop #: WSC 00441 210 61830
    1 Fault Found:
    00562 - Sensor for Oil Level/Temperature (G266)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 00000011
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 205
    Mileage: 141256 km
    Time Indication: 0
    Date: 2010.11.09
    Time: 23:38:03
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 25001045210110
    Coding: 3D0F0B40070101
    1 Fault Found:
    00381 - Databus Instrument Cluster
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 1
    Fault Frequency: 44
    Reset counter: 245
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D01 Serial number: AUX7Z0D5FNE0CW
    Shop #: WSC 00441 210 88110
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
    Part No: 8P0 959 801 E
    Component: Tuersteuerger. H10 0030
    Coding: 0000048
    1 Fault Found:
    00932 - Electric Window Motor; Drivers Side (V147)
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 G
    Component: EPS_ZFLS Kl.10 1301
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H02 0040
    Coding: 008000186D288505489AC63000
    Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Part No: 1K0 907 719
    Component: Neigungssensor 003 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0010
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
    Part No: 8P0 959 802 E
    Coding: 0000048
    1 Fault Found:
    00933 - Electric Window Motor; Passenger Side (V148)
    Address 56: Radio
    Cannot be reached
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
    Component: PTC-Element 0404
    Revision: 00700000 Serial number:
    I will clear fault codes tomorrow and re run vag com after taking her for a test and see if there any change and repost but any help or advice now will be appreciated.
    Roosterman
  2. Re: Various Faults on A3 2.0tdi
    Southern County Softy
    20 Post(s)
    the drivers door lock problem could be a broken wire in the loom between the door and the "A" pillar.
    I had this problem on my daughters A3, the problem was the microswitch built into the lock.
    Got a new one on Ebay for £40, the dealer will want around £90..
    A4 2.5 tdi QS (mapped)
  3. Re: Various Faults on A3 2.0tdi
    Jan 2010
    Wakefield, West Yorkshire
    Hi and welcome
    After the battery has been disconnected there are likely to be a few areas where re-setting is required. You need to check the user manual for synchronising the immobiliser and re-setting the electric windows.
    Clear all fault codes and start again to see what pops up a second time and then check the manual
    Good luck
  4. Re: Various Faults on A3 2.0tdi
    Dec 2010
    Ramsgate Kent
    How do I Synch Immobiliser? cant find that in the manual.
  5. Re: Various Faults on A3 2.0tdi
    20 Post(s)
    did you clear the codes, what ones have come back?
  6. Re: Various Faults on A3 2.0tdi
    Jan 2010
    Quote Originally Posted by Roosterman View Post
    Sorry mate - rewind. I didn't mean synchronise the immobiliser I meant synchronise the remote control key fob !
    If you can drive the car at all then there is no problem with the immobiliser !
  7. Re: Various Faults on A3 2.0tdi
    Dec 2010
    Ramsgate Kent
    Kite I cleared all codes after the synch of windows and these are the results. Auto window works but still getting the fault?
    Now a newbie question in the reults there are items with no fault code does this mean this item is faulty but does not know what the fault is or is it ok?
    After synch of windows still fault there.
    Sunday,12,December,2010,20:46:11:13314
    Chassis Type: 1K0
    VIN: WAUZZZ8P Mileage: 142280km/88408miles
    01-Engine -- Status: OK 0000
    Coding: 0000072
    Coding: 0023174
    Coding: 16187408
    Shop #: WSC 00000
    Coding: 0011602
    Coding: 0000012
    Coding: 0004408
    Coding: 0000048
    1 Fault Found:
    Coding: 0000048
    1 Fault Found:
    Address 56: Radio
    Cannot be reached
  8. Re: Various Faults on A3 2.0tdi
    20 Post(s)
    you could try resetting the windows with VCDS.
    Not finding the radio could be to do with the parrot kit.
  9. Re: Various Faults on A3 2.0tdi
    Dec 2010
    Ramsgate Kent
    I am assuming the reason the 2 alarm buttons on the drivers door do not work is because the door thinks it is shut all the time due to the faulty microswitches in the lock.
    Does this seem right to you guys?
    Regarding my Climate Control I am pleased/embarassed to say I was being a newbie and turned it off by taking the - down as far as it would go on the fan. RTFM!
    Although the + for the fan does not work at all, flick it on auto and the fan will blow as required so can live with this as long as it does not damage anything.
    I will retry sync tomorrow and think I should get some radio keys pop that out to check connections for the ipod Denison cradle.
    The car also has a nokia handfree installed and I assume this is connected to the denison system guess I will have to have a rummage to find out.
    Thx Roosterman
  10. Re: Various Faults on A3 2.0tdi
    Dec 2007
    Launceston, Cornwall
    A rather belated reply I'm afraid, but I think you are right about the 2 alarm buttons on the driver's door being affected by the lack of door-open signal. Tried it just now on my A3:
    Open door, press alarm-disabling button, its light comes on.
    Close latch plate fully by hand (as though closing door), light goes out.
    Lift handle to open latch, but control movement of latch plate by hand and listen for click of door-open microswitch. When it clicks, light comes on again, at same time as door edge light comes on.
    (Light only goes away after vehicle is locked).
    If you are interested in a diy solution, I've submitted a How To guide on repairing this microswitch - awaiting approval - I'll post a link here when it's available. Edited 4 Jan 2011: https://www.vwaudiforum.co.uk/forum/s...d.php?t=112069
    When you've sorted the door-open signal problem, I hope you'll be able to post a reply about it on the guide. Good luck!
  1. Audi A3 personal review (MY10/11)
    By tlionhart in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 30-08-2010, 12:37 AM
  2. New Audi A3 2.0TDI 115g/km
    By onemanparty in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-05-2010, 09:26 AM
  3. The new generation Audi A3
    Last Post: 28-04-2008, 07:04 PM
  4. World Debut For The All New Audi A3 Cabriolet
  5. A3 Range Update
    Last Post: 14-02-2005, 11:35 PM
