Thread: Airbag Deactivation Warning Lamp
  1. Airbag Deactivation Warning Lamp
    Jun 2010
    Derby
    during the recent code spell my air bag light came on & off intermittently
    Just had the codes read..
    01578 Passenger side deactivation warning lamp .. 009 open or short to ground, anyone any idea where this could be ?
    Mike
    2003 allroad 2.5TDi (AKE Engine)
    2007 Avant 2.0Tdi (BRE Engine)
  2. Re: Airbag Deactivation Warning Lamp
    Mar 2008
    High Wycombe
    There's a lamp in the ceiling of mine (next to the map reading light) which says "Passenger airbag deactivated" if I turn the airbag off with the switch in the glovebox.
    So it could be between the switch and the light, or the light and the control module. I'd try looking in the headlining (you should be able to get a look in there by removing the interior light cluster)
    (Mine's a 2000 A6 2.4 SE)
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: Airbag Deactivation Warning Lamp
    Jun 2010
    Derby
    Thanks, I'll turn off the switch in the glovebox and see if a light comes on, maybe a bit of condensation whilst so cold
  1. A6 Airbag warning symbol after installing glove box
    By bdm2510 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-09-2010, 12:54 PM
  2. Replies: 4
    Last Post: 21-07-2010, 09:10 PM
  3. Passenger Airbag Deactivation Fault
    By jluckcuck in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 21-05-2008, 10:50 AM
  4. Airbag warning lamp ECU - £500
    By mlm in forum A2
    Last Post: 07-02-2008, 04:34 PM
  5. Airbag warning lamp ECU - £500
    By mlm in forum Audi A4 - Archive Topics
    Last Post: 18-01-2008, 12:23 AM
