Thread: traction control light always on
Results 1 to 10 of 14
  1. traction control light always on
    Mar 2009
    First things first... Hi everyone Have been a member for a while but haven't been on for a while due to some numpty lorry driver writing off my old audi coupe 2.3e.
    Good news is i'm back as an audi owner with a A3 1.8t 2001 plate, woo-whoo. Got to love Audi's
    Enough rambling though as i do need some
    The traction control warning light stays on all the time. I read somewhere that it could be the MAF sensor. The car was a bit rough at idle and having checked the MAF i found it was faulty. However this has now been changed and after a run down the dual carrige the warning light turned off BUT as soon as drove the car again (about an hour later) the traction control light was back on and stays on
    Does anyone have any ideas what the problem could be?? I've got a VAg reader and will carry out a scan on the weekend but thought someone on here might be able to give me a heads up of possibilities. Any help would be greatly appreciated.
  2. Re: traction control light always on
    Mar 2008
    High Wycombe
    I wouldn't have thought the MAF would trigger the traction control light, but Crasher's post below sets me right about that.
    Are you sure you haven't got the traction control turned off? When I turn mine off, the light comes on constantly - when it's activated by wheelspin, it flashes.
    A fault code read might help. You could also go into the ABS system measuring blocks and check that the wheel speeds are all the same (get someone else to drive while you do this). The ABS sensors are what triggers the traction control, so a faulty one might activate the light. I'd have thought that would also make the ABS kick in every time you brake though.
    Last edited by NickPicks; 10-12-2010 at 09:32 AM. Reason: Corrrection due to Crasher's comments.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: traction control light always on
    135 Post(s)
    2038 Post(s)
    Certain engine faults can cause the ABS to store code “01314 Engine control unit” and I have seen AMM faults do this.
  4. Re: traction control light always on
    Mar 2009
    Thanks for the responses.
    When i press the ESP button nothing changes, which leads me to believe the traction control is turned off and in safe mode (not 100% if that's a correct assumption though).
    Nickpick - could you explain the ABS measuring blocks please? i've never heard of this before. Is it a simple test you do at home or would i need to go to a garage? I have the previous years mot with brake testing which shows that one side was braking slightly more than the other (do you mean this?).
    Crasher - what's the AMM?
  5. Re: traction control light always on
    Mar 2008
    High Wycombe
    Measuring blocks:
    What type of vag reader do you have? To use measuring blocks, I think you need vag-com or VCDS (the new name for vag-com). For your car, you could get a cheap cable for about £15 from ebay, and use the shareware version of vcds light. Depending on your reader, it might be able to measure blocks.
    If you're using vag-com / vcds, then you open the ABS module, and click on 'measuring blocks'. I can't remember which one, but one of the blocks is wheel speeds - you then get someone else to drive slowly forwards in a straight line, and you can watch the speeds of each wheel sensor.
    My comment about ABS speeds might be a red herring though. If it's that, then I'd expect the ABS to moduilate and vibrate the pedal every time you brake.
    I'd say your first thing to do is to read the fault codes with vag-com / vcds, and see what codes are stored. then clear the codes and see what comes back.
    The AMM is the Air Mass Meter (also called the Mass Air Flow meter or MAF)
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  6. Re: traction control light always on
    Mar 2009
    Thanks for that.
    I've got a coder reader from a link on this forum. Here's a link to the product: http://www.gendan.co.uk/product_GDEOBD.html
    Think the best thing is to read the codes tomorrow and take it from there. Will post the results a.s.a.p.
  7. Re: traction control light always on
    Oct 2010
    NZ
    My guess is G200 sensor fault (if you have one). I had the same problem with the ESP (A3 1.6 2001) with these faults in Vag-Com:
    01423 - Lateral Acceleration Sensor (G200)
    57-00 - Electric Circuit Failure
    27-10 - Implausible Signal - Intermittent
    My G200 sensor's part number is 1J0 907 651 A or 1J1 907 639, your should be the same...
    There is a very cheap solution, just follow one of these:
    link1
    link2
    Works fine on mine
  8. Re: traction control light always on
    Mar 2009
    ok, went to do the code reading today and found the traction control light not on anymore. ESP button all works and felt great when i took it for a spin.
    Hence to say i didn't do the code reading in the end.
    So looks like it was the MAF/AMM in the end fingers crossed.
    Big thank you to everyone for their comments and hope i can return the favour one day
  9. Question Re: traction control light always on
    Mar 2009
    Hey guys,
    hadn't driven the car for a while due to coming down with the dreaded man-flu
    traction control light now comes on and off intermittently basically every other drive!?
    i've also completed a code read and it the showed the following codes:-
    16486 - MAF low input??? i've chnage the MAF for a new unit though
    17705 ???
    17535 - Long term fuel trim ???
    17545 ???
    18010 - power supply (B+) terminal 30- low voltage????
    01423 - which porterxx recently identified as the g200 sensor
    an anyone shed some light on what all this means?
    Again many thanks for any help given.
  10. Re: traction control light always on
    May 2010
    Devon England
    Quote Originally Posted by barnabyho View Post
    Hey guys,
    17705 ???
    17545 ???
    have you cleared the codes and these's came back? i think that 17535 is to do with the MAF, did you fit a genuine MAF or a cheap one?
  1. Please Help A4 electrics gone wild
    By Deek2005 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-11-2010, 06:32 PM
  2. Replies: 10
    Last Post: 28-06-2010, 09:12 PM
  3. Replies: 0
    Last Post: 11-04-2010, 04:20 PM
  4. Emission Control System Warning Light (A4 Avant 1.9TDi 130PS AVF Multitronic)
    By trlaing in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-06-2008, 10:59 PM
  5. A4 (02) Traction Control Problem
    By Mattlock in forum Chat - Anything with wheels
    Last Post: 26-11-2007, 02:33 PM
