Thread: Best way to flush coolant??
  1. Best way to flush coolant??
    Jan 2011
    Essex UK
    Hi there,
    The metal water pipe (that runs round the right of the engine) on my 1996 1.8GL has corroded and is leaking coolant so I need to replace it. I'm guessing I will lose a reasonable amount of coolant removing the pipe and looking at the state of the coolant it probably needs changing anyway - doesn't look like G12+ in there and would explain the corroding.
    Couple of questions if I may?
    1. To fully flush the system will I need to remove the thermostat (hoping not to but guessing it is inevitable)?
    2. To flush the system is it simply a case of:
    a) running water through the top rad hose into the radiator to flush the radiator and;
    b) running water in through the expansion tank to flush the engine (assuming the T-Stat is out)?
    Thanks for any advice?
    David
  2. Re: Best way to flush coolant??
    Nov 2010
    southampton england
    Leave the stat in ..thatll need a clean out too..use some RADFLUSH,fill the system with it and clean water,run the engine up to temperature,then dump the system again(into a container..not the drain..lol),then flush with clean water,fill the system with a 50/50 mix of antifreeze and water,
  3. Re: Best way to flush coolant??
    Jan 2011
    Essex UK
    Thanks for the advice.
    Sorry just one more thing, which pipes do I disconnect then and will water run through the stat if its not open - I assumed it would retain the water that is in the engine??
  4. Re: Best way to flush coolant??
    Pembrokeshire
    22 Post(s)
    i remove the stat first, usually, then add a flush, run it, drop the coolant, refil with water , run it, drop it, and keep doing that until the water comes out clean. depending on how bad it is, a hose can be used , put into the top hose, bottom hose, heater pipes etc, to get anything else out. put it all back together, new stat, refil with coolant. bleed, test drive, check level.
  1. Replies: 21
    Last Post: 04-07-2012, 10:32 PM
  2. 1.8T Common Troubleshooting Guide
    By blacksline in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2010, 12:17 AM
  3. Replacing engine thermostat and coolant flush
    By charbel89 in forum Golf MK3 - 1993 - 1999
    Last Post: 21-06-2010, 09:40 AM
  4. What is the safest way to dispose of old G12 Coolant ?
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 13-04-2008, 03:38 PM
  5. Coolant system renewal!
    By Pernicitus in forum Golf MK3 - 1993 - 1999
    Last Post: 22-10-2007, 11:39 PM
