Thread: audi a6 2006 2.0 tdi air and pollen filter replacement help
Results 1 to 10 of 12
  1. audi a6 2006 2.0 tdi air and pollen filter replacement help
    Nov 2008
    hi all,
    new to all this so please be patient.
    how do i replace the air and pollen filters in my 2006 a6 2.0 ltr tdi ?
    everyone tells me it's a simple job but no one will tell me how.
    one mans simple is anothers nightmare.
    many thanks
  2. Re: audi a6 2006 2.0 tdi air and pollen filter replacement help
    Air filter - undo clips in air filter box, remove top cover and replace filter
    Pollen filter - you access it behind glove box, never done it myself, but seen how its been changed
    46 Post(s)
    There's a guide on the Internet somewhere and I'll find it when I'm home from work
  4. Re: audi a6 2006 2.0 tdi air and pollen filter replacement help
    PM me your email address and I'll send you the info. Quote the year, model and engine in the message. Regards Peter
  5. Re: audi a6 2006 2.0 tdi air and pollen filter replacement help
    Nov 2008
    Quote Originally Posted by bakili View Post
    many thanks,
    is the air filter box beneath the engine cover and will i be able to id it easy?
    cheers
    kev
  6. Re: audi a6 2006 2.0 tdi air and pollen filter replacement help
    Nov 2008
    Quote Originally Posted by Peter D View Post
    hello Pete,
    it's kev@tarawa.co.uk
    2006 a6 2.0 ltr tdi s line saloon
    thanks for help
    kev
  7. Re: audi a6 2006 2.0 tdi air and pollen filter replacement help
    Quote Originally Posted by tarawa.kev View Post
    many thanks,
    cheers
    kev
    air box is behind right headlamp, if you stand facing front of you car, its on left side. You will see 2 screws near bonnet locking mechanism, undo them to remove front bit of air box, which connects to the grill. It should be few clips in the middle of air box, just unclip them to remove top bit of air box. you will see round air filter inside.
  8. Re: audi a6 2006 2.0 tdi air and pollen filter replacement help
    Nov 2008
    you make it sound soooooooooooooo easy.
    you don't know me - mr two left hands.
    one for the weekend i think.
    i'll let you know and many thanks for your help.
    kev
  9. Re: audi a6 2006 2.0 tdi air and pollen filter replacement help
    Dec 2012
    newtownabbey
    could any of you kind gentlemen forward me the link of air and pollen replacement. thanks :-)
  10. Re: audi a6 2006 2.0 tdi air and pollen filter replacement help
    Apr 2009
    Surrey
    183 Post(s)
    Quote Originally Posted by skinso View Post
    This should get you started on the pollen filter http://tech.bentleypublishers.com/se...n%20Filter.pdf. On a RHD drive car the access is from the driver's footwell so you can ignore all the stuff about removing the glovebox. You simply remove the flap to the left of the clutch pedal and then pull out the first filter, then reach up and pull down the second filter and pull it out. Replacement is the reverse of removal, when I did it the major challenge was pushing the upper filter up high enough so I could fit the second filter. Take your time and it can be done. I used filter's from Eurocarparts and they were cheaper than Audi and as far as could see in comparing them with the ones I removed no different, except of course the disgusting state of the old ones. They also had fitting instructions in the box. Worth having a hoover to hand to vacuum out all the rubbish before fitting the new filters. Also note that the filters only work one way round so make sure the air flow arrows on the new ones point in the same direction as the old one
  1. Question Pollen Filter Change
    By unklesammy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-05-2010, 09:07 PM
  2. Question Audi A6 2.0 TDi 58k miles full inspection service
    By iBRUK in forum Chat - Anything with wheels
    Last Post: 20-01-2010, 07:14 PM
  3. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  4. At home on all roads and tracks - Audi A6 allroad quattro
    Last Post: 05-03-2006, 07:53 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
