Thread: T5 Stereo query
  1. Lightbulb T5 Stereo query
    I have a 2.5 174 T5 Kombi 2005 which has a vw gamma standard cassette player and vw 6 cd changer above it. I would like to change it to a double din vw sat nav unit (mdf2 rns). I know i may have to 'modify' the dashboard for it to fit and add a different loom behind (i've seen them on eb ay) but if anyone could shed a little light on this i would be most greatful-
    thanks
    May 2007
    17 Post(s)
    Is that the same unit as used in Toureg and Mk5 golfs? If so, then it's not a double DIN unit. And don't forget to get the GPS aerial.
    Jim.
  3. stereo
    [Hi there, yes it is the same unit as the toureg and new golf. i thought the fascia was larger but the back metal casing was a double din. it seems that my dash has a cut out to fit the larger fascia but if you say its not a double din then i doubt it will fit anyway.
    thanks
    May 2007
    17 Post(s)
    Check this thread : https://www.vwaudiforum.co.uk/forum/s...5780#post45780
    Someone has already tried to fit an RCD300 radio (froma MK5 Golf) to an older model Passat with a double DIN dash. It didn't fit.
    Jim.
  5. radio
    Right then, that seems fairly conclusive. thanks for your help. I think i may just leave it all alone!
    cheers ncik
  1. t4 power query
    By mattspo in forum New Member Introductions
    Last Post: 08-04-2007, 05:20 PM
  2. TT Stereo cover query...
    By RavenBlackTT in forum TT - 8N Forum - 1998 - 2006
    Last Post: 05-04-2007, 04:28 PM
  3. Tow Bar query...
    By Nebooaw in forum Passat - Archive Topics
    Last Post: 09-03-2007, 11:31 PM
  4. Query
    By Ben in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-02-2007, 04:24 PM
  5. Touran query
    By excossack in forum Touran - Sharan - Caravelle
    Last Post: 09-12-2006, 08:12 PM
