Thread: Parking Brake Switch / Radio Code
  1. Parking Brake Switch / Radio Code
    Apr 2010
    Ashford, Middlesex
    Over the last couple of weeks I have been getting more and more instances of the parking brake not working (sometimes when putting it on, other times when trying to take it off), and it has gotten to the point now that I am simply not using the parking brake at all.
    Now, reading on here, I know that the first thing to try is to change the switch.
    I know that it is a general recommendation to disconnect the battery when working on vehicle electrics, although must confess that I have ignored this a number of times over the years and never had a problem - however, I have never had a car with such a complex control system before.
    So, do I NEED to disconnect the battery, or is it only a general precaution?
    If I do need to disconnect the battery, how easy is it for me to obtain the radio code for the car before going ahead, as I didn't get one with the car?
    Lang may yer lum reek!
    Current: '09 Audi A4 Avant SE TDI (143)
    Previous: '56 VW Passat 2.0TDI SE - I survived 'BKP' ownership!
  2. Re: Parking Brake Switch / Radio Code
    Mar 2009
    Sleaford, Lincs, UK
    If you're replacing the button? Then you don't need to take the battery out, unless you need to clear the fault, which, if you don't have ignition on, it won't log.
    If the handbrake is stuck on/off and you want to reset the computer, try setting the alarm off first, I've heard this also can reset systems?
    As for the radio code, I did mine a few times and was never asked for a time, go into settings and turn the code off
    Think I'm right, however I'll be told otherwise by other knowlegeable people on here
    07 Passat SEL Sport TDI 170 R
    Deep Pearl Black
  3. Re: Parking Brake Switch / Radio Code
    Mar 2009
    York
    Doesn't matter about disconnecting battery - I just did a quick swap of switches.
    As far as the radio code goes, the radio supplied with your vehicle has the code embedded in the VCDS (not accessible though). So you can remove it if you want to add third party stereos, and then put it back in when you sell the car. You will not be asked to input the code again. However if you try to put your own radio in someone elses Passat, or vice-versa, then you will need the code.
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  4. Re: Parking Brake Switch / Radio Code
    Apr 2010
    Ashford, Middlesex
    Thanks guys! That is why I love this forum - straight answers, and quick too.
  5. Re: Parking Brake Switch / Radio Code
    Mar 2009
    Sleaford, Lincs, UK
    Hope you get it sorted dude
    Deep Pearl Black
  6. Re: Parking Brake Switch / Radio Code
    Apr 2010
    Ashford, Middlesex
    Just short of £24 lighter, and it appears I now have a working parking brake again. Thanks again for the help
  1. Parking Brake Fault - on 2 cars!!
    By VWfrust in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-03-2015, 12:18 AM
  2. Retrofitted RNS-510, Changed GW, now a lot of errors
    By bjuran in forum VCDS - Help Requests
    Last Post: 09-07-2011, 01:37 PM
  3. A6 Avant Radio Code Input
    By rozzski999 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-09-2009, 05:46 PM
  4. Healp needed VAG com
    By Snooze1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2009, 07:47 AM
