Thread: Outside temperature guage
  1. Outside temperature guage
    Does anyone know where the outside temperature sensor is? I have an inaccurate outside temp reading on the dash and on the climate control, ive changed the sensor behind the front bumper nearside but its still teh same wrong reading, ive now removed that sensor all together and still getting inaccurate readings so there must be another outside temp sensor hiding somewhere??
  2. Re: Outside temperature guage
    Oct 2005
    The sensor you've replaced is the outside temp sensor as far as I'm aware.
    Have you had the car scanned for fault codes?
  3. Re: Outside temperature guage
    Yes have scanned it and got 00779 - Outside Air Temp Sensor (G17). I thought the changing that outside sensor would cure it but with replacement sensor or no sensor connected at all i still get the same inaccurate outside temperature reading!
  4. Re: Outside temperature guage
    Oct 2005
    I presume you've cleared the fault and rescanned?
  5. Re: Outside temperature guage
    The error code won't clear, as soon as I clear it, it returns.
  6. Re: Outside temperature guage
    Oct 2005
    Which of the following is the error;
    00779 - Outside Air Temperature Sensor (G17): Open or Short to Plus
    or
    00779 - Outside Air Temperature Sensor (G17): Short to Ground
    The latter indicates a broken sensor and would be resolved by fitting a new one (which you've done), the former indicates a fault in the wiring between the sensor and the cluster/climatronic
    The Ross-Tech Wiki suggests checking measuring blocks for the sensor.
    In a Passat it's group 006 and the values are, Calculated Temp, Fresh Air Duct Temp (G89), Outside Air Temp (G17) and Sunlight Photo Sensor (G107)
    Not sure if it's the same for the MKIV (I presume it is).
  7. Re: Outside temperature guage
    My 00779 was the open or short to plus. Not the simple fix i hoped for. Will look at the wiring and measuring block values next.
    Cheers for your feedback..
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. Just bought VCDS and need some help with Passat FSi codes
    By nr800 in forum VCDS - Help Requests
    Last Post: 21-11-2010, 08:21 PM
  3. 170 turbo from a golf into a passat
    By toddy2008 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-11-2010, 11:19 AM
  4. Please Help High Temperature showing on guage but no apparent overheating or loss of coolant
    By Broadsman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-10-2010, 07:35 PM
  5. Numerous Details on Digital Air Con Display
    By sooty in forum Chat - Anything with wheels
    Last Post: 21-01-2008, 08:09 AM
