Thread: Locking/Frozen Rear brakes
  1. Locking/Frozen Rear brakes
    Mar 2008
    I've had a problem with my rear brakes ever since it’s gotten really cold they have locked/frozen twice now in the morning. First time I rocked the car and they release themselves but this morning there was no budging the rear wheel on the drivers side. My road is totally frozen so there is very little traction.
    Any ideas?
  2. Re: Locking/Frozen Rear brakes
    Sep 2008
    chester
    17 Post(s)
    I would say you've got a frozen hand brake cable(s)or the servo is freezing up, but the fronts usually stick when that happens,try using a heat gun or the kettle to warm them gently see if that free's them.It'll maybe get you going for now but they'll re-freeze again.
  3. Re: Locking/Frozen Rear brakes
    I suspect water is freezing between components causing the handbrake to remain engaged. This could either be caused by the pad sticking to the disc, in which case this is little you can do. If you don't park on a slope try engaging the handbrake with less force.
    Or it could be the caliper which is sticking. You could have the caliper stripped, cleaned and greased (which should be done at a pad change) which alleviate the sticking, or get busy with the hair drier on those cold mornings
  4. Re: Locking/Frozen Rear brakes
    Cork
    Don't use the handbrake in extreme cold weather. It's a known problem with most handbrakes. Moisture on the pads and the disks freeze together. Ask any one on a scandanvian auto forum.
    AUDI A4 Avant 2.0TDI S Line
    | My Slipper |
  5. Re: Locking/Frozen Rear brakes
    Apr 2009
    Quote Originally Posted by defsix View Post
    X 2. If its gonna be less than -3c, there's a risk of the
    handbrake freezing.
    Regards
    Jim
  6. Re: Locking/Frozen Rear brakes
    Feb 2010
    Norfolk uk
    Just leave it in gear,it won't go anywhere,that's what I do
  7. Re: Locking/Frozen Rear brakes
    Mar 2010
    stroud uk
    Happened to me yesterday. Just the extreme cold making it sticky.
  1. New bentley continental supersports convertible
    Last Post: 02-03-2010, 08:04 PM
  2. New bentley continental supersports convertible
  3. Question How does front and rear brakes work?
    By tyberwan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-06-2009, 09:36 AM
  4. Got A problem With Rear Brakes
    By taffys-A4-Turbo in forum New Member Introductions
    Last Post: 04-03-2008, 12:37 AM
  5. Rear brakes
    By britaxcooper in forum Golf MK3 - 1993 - 1999
    Last Post: 26-12-2007, 11:13 AM
