Thread: Heater Blower Motor Fuse Blowing
Results 1 to 10 of 11
  1. Heater Blower Motor Fuse Blowing
    Dec 2010
    Kendal
    The 30A fuse on the heater blower motor circuit in my Passat blows intermittently.
    The vehicle has a climatronic AC control module. It seems that when the unit is in AUTO the fan will operate but then the fuse will blow. When I put the climatronic into MANUAL and keep the fan speed at a medium speed the fan keeps operating.
    Having looked at the circuit and at various discussions on heater blower motors I am coming the the view that the problem may be the blower motor resistor unit.
    Before I go off to the scrappy I'm wondering if anyone else has had similar symptoms and found a fix.
  2. Re: Heater Blower Motor Fuse Blowing
    Norfolk
    Blowing the 30A fuse suggests the blower motor has had it.
  3. Re: Heater Blower Motor Fuse Blowing
    Dec 2010
    Kendal
    The motor is fine - it works when connected directly to a 12v supply and is currently working when the climatronic unit is in MANUAL. If I put the climatronic in AUTO the fuse blows - not immediately - but at some operating point which I haven't yet identified. My thinking is that as it switches the resistors in/out there's a short causing the fuse to blow. I'm wondering if anyone else has had the problem and fixed it with a resistor unit replacement.
  4. Re: Heater Blower Motor Fuse Blowing
    Norfolk
    I think you are correct. The resistor comes out the bottom of the fan housing so take it out and test the resistance. In my experience motor comutator/brush problems usually cause the current to spike and blow the fuse, but a shorted resistor pack would do the same thing.
  5. Re: Heater Blower Motor Fuse Blowing
    Dec 2010
    Kendal
    Thanks for the reply. The unit on my car is separate from the fan and is mounted on the bulkhead with a big heat sink on the back of it (VW Part No 1JO 907521). I'm off to the scrap yard once the snow melts to see if I can scavenge a replacement. I think I'll get a big box of fuses as well. I'll post a report on the results.
  6. Re: Heater Blower Motor Fuse Blowing
    Dec 2010
    Kendal
    Well the snow finally melted and I got down to the scrap yard and luckily obtained
    a resistor unit - (£5 rather than £80 from a dealer). Put it in and after about 5 minutes the fuse blew again. After much cursing and perusing of my Haynes Manual (ISBN 1 85960 917 1) I noticed that Diagram 11 also includes a feed from fuse 25 to the air compressor clutch and the A/C cutoff module. I had just been looking at Diagram 10 which I thought was the full story regarding fuse 25.
    So I've isolated the supply to the air compressor clutch - the fuse no longer blows.
    One problem sorted another found. Ho-hum.
  7. Re: Heater Blower Motor Fuse Blowing
    Oct 2012
    Offaly, Ireland
    I taught i was the only person in the world with this problem. like your problem my 30amp fuse keeps blowing any time i turn up speed of the climatronic heater. i also changed the resistor/capacitor. can you tell me how you isolated the supply to air compressor please, this would be my 3rd winter without heater fan. DAMN CONDENSATION!!!
    I know this is a year later but if you or anyone who knows this problem see's this pleeeeeeeeeeeeease reply with solution...many thanks
  8. Re: Heater Blower Motor Fuse Blowing
    Dec 2010
    Kendal
    Quote Originally Posted by aimcn View Post
    There's a connector to the clutch unit in the engine bay. I can't remember if you have to take the compartment cover off from underneath to get at it. Unclipping it sorted the blower fan fuse problem. (I refitted a replacement aircon compressor it wasn't too successful but that's a completely different matter). My blower fan is still working.
  9. Re: Heater Blower Motor Fuse Blowing
    131 Post(s)
    1974 Post(s)
    Which fuse number keeps blowing, number 5?
  10. Re: Heater Blower Motor Fuse Blowing
    Dec 2010
    Kendal
    It was Fuse 25 in diagram 10 (Heater Blower etc) in my Haynes Manual. However, as noted, this fuse also appears in diagram 11 (Air Con). Diag 10 doesn't show this hence it took me some time and £5 for a replacement resistor unit from the scrappy before I sorted the problem.
    JP
  1. How To Octavia Mk1 heater blower swap.
    By Pastedavid in forum Octavia
    Last Post: 17-02-2010, 05:08 PM
  2. Allroad heater blowing cold air
    By snugglebum in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-11-2009, 08:32 PM
  3. Sharan Heater Front Blowing
    By robinbhogal in forum Touran - Sharan - Caravelle
    Last Post: 07-04-2008, 04:56 PM
  4. Heater Blower Motor or something else?
    By Audi 80 Man in forum 80 - 90
    Last Post: 08-01-2008, 06:54 PM
  5. Heater core replacement 93 passat VR6
    By farmhemi in forum Passat - Archive Topics
    Last Post: 05-01-2008, 04:25 AM
