Thread: Brake pedal hissing......
  1. Brake pedal hissing......
    VAGMAN2 Guest
    I have a 2000/TDI and for the past few months, the brake pedal has been hissing/making a whistle noise (!!) sometimes, when you depress it. It seems worse when the car has been standing for several hours. My first thoughts are is there air in the system??? The brakes were bled 3 years ago.
    Anything I can do to check/diagnose the problem/fix???
    Thanks-in-advance!
  2. Re: Brake pedal hissing......
    Mar 2008
    High Wycombe
    The book says you should change brake fluid every 2 years anyway.
    Is it a hiss, of could it just be the squeak / rub as the pedal moves against its bearing?
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: Brake pedal hissing......
    Sep 2008
    chester
    17 Post(s)
    Sounds like your servo is leaking vac on the pedal side,for get about bleeding the brakes, as air in the system is only a few air bubbles there's no pressure in there!Although as the previous poster says fluid change every 2 years.
  4. Re: Brake pedal hissing......
    Feb 2011
    Barnoldswick
    hi had the same problem with my a3, turned out to be the hose from manifold to pressure the braking system was leaking air. changed the hose and everything was fine no hissing noise. hope this helps
  1. Question Brake Pedal Hissing
    By Kashew in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 01-02-2010, 07:16 PM
  2. Brake pedal sensor intermittent...
    By JohnW78 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-12-2009, 11:43 AM
  3. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  4. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  5. Brake pedal hissing!!
    By dainott2105 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-05-2008, 07:50 AM
