Thread: Mystery Coolant loss
  1. Exclamation Mystery Coolant loss
    Sep 2007
    North Wales
    Hi all,
    My Passat 1.9 TDi (ATJ) has sprung a leak, its a difinite leak as when its warm it's dripping from the belly panel.
    I've had the panels off and looked and it appears to be running down from above the starter motor but can't see anything.
    Its in with a mechanic at the moment and he can't see where its coming from either.
    Can anyone out there shed any light on this? Or has anyone had the same problem?
    There is no sign of Head Gasket leak/damage and there's no fault codes showing, its a mystery.
    Steve. 2002 (52) Passat 1.9 TDi 130bhp (AWX)
  2. Re: Mystery Coolant loss
    Jul 2010
    Brighton
    the common place is at the very bottom of the radiator they usually let go there
  3. Re: Mystery Coolant loss
    Apr 2009
    Somewhere....Over The StrongBow
    Its an auto-box, so it might be gearbox coolant pipes.
    Regards
    Jim
  4. Re: Mystery Coolant loss
    Dec 2009
    hounslow
    Quote Originally Posted by yaman View Post
    Regards
    Jim
    wouldn't they drip PAS fluid instead of water?
  5. Re: Mystery Coolant loss
    Apr 2009
    Quote Originally Posted by couga View Post
    Sorry, i should have said bell-housing mounted coolant pipes.
    Not sure if there's an engine-oil cooler feed-pipe beside bell-housing,
    on a ATJ.
    The EGR is water-cooled, check the feed-pipe.
    Regards
    Jim
  6. Re: Mystery Coolant loss
    Jun 2007
    Take a look at the side coolant flange as the o ring is a common source and it runs around the bell housing. Replace the flange as well though if it is that.
  7. Re: Mystery Coolant loss
    Aug 2007
    Quote Originally Posted by y2ksparky View Post
    An old post but I too have a loss of coolamt that is proving difficult to trace. Can you be more specific about the flange you mentioned please ?
    ian
  1. Please Help 1.9TDi (AFN) coolant loss - poss head gasket failure, opinions required
    By Mockenrue in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-01-2017, 10:56 PM
  2. 1999 1.9Tdi (115bhp) coolant loss
    By dulaman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-11-2010, 03:32 PM
  3. Mystery Coolant Loss ??
    By TheMadhatter in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-04-2009, 11:48 PM
  4. Please Help Inexplicable TDi Coolant Loss
    By sntee in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-04-2009, 03:41 PM
  5. Coolant loss problem
    By PTEK in forum Archive posts
    Last Post: 23-02-2007, 11:01 PM
