Thread: A4 instrument cluster
  1. A4 instrument cluster
    Is it possible to use an instrument cluster from another A4? speedo and rev counter have packed in-is the unit matched to the car in any way? I know the car still starts and runs with no cluster so can't be part of immobiliser,thanks for advice
    car is a 1995 TDI SE by the way
    london/ UK
    Hi, you need to get the exact match then, with diagnostic equipment(vag com works fine...) and the log-in code you could code the new instrument cluster to your car. The instruments cluster contains the immobiliser and if codded incorectly, it will not let the car start ! I suggest you see a good vw specialist or, if you live close to London, i could help ... Regards, Chris.
    ok just bought this car from an auction the other day for £650,also need a front section for the exhaust (has split at flexi coupling near turbo)-hoping to get it through an MOT,my location is leeds so bit too far from you unfortunately
  1. Fitting a new instrument cluster
    By descarl in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-09-2007, 01:32 PM
  2. 2001 vw jetta glx instrument cluster not lit (bora uk)
    By aaronchristen in forum Bora - 1998 - 2005
    Last Post: 13-03-2007, 05:27 PM
  3. A4 instrument cluster change
    By itsallsorted in forum Audi A4 - Archive Topics
    Last Post: 13-01-2007, 02:13 AM
  4. A3 instrument cluster failure
    By chrislodge99 in forum Archive posts
    Last Post: 18-09-2006, 08:53 PM
  5. Replies: 4
    Last Post: 05-11-2005, 06:52 PM
